03-26-2008, 04:33 PM | #1 |
empty tank at a quarter??
my gas gauge only goes to 1/4 tank when it is empty. any ideas? when i fill it it goes all the way up. Would this matter if its the right tank? don't know but was in it when i bought it. could it be a wrong sending unit? any suggestions would be helpful
GARY |
03-26-2008, 04:39 PM | #2 |
Re: empty tank at a quarter??
It could be that your sending sends the right OHMS at full but doesn't go as low as your tank, or it could be rusty or something and physically sticks at 1/4 tank
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
03-26-2008, 06:00 PM | #3 |
Pull the sending unit and check to see if the float is level with the suction line when all the way down. Also make sure it is not in contact with the tank when installed. If this is not it then it is probably a bad spot in the resistor wire
69 Chevy 4x4 383 Power |
