03-27-2008, 08:43 AM | #1 |
3 hole gauge cluster help
looking for some measurements guys, I'm throwing this idea around in my head. for my '72 gauges I'm thinking about using the 3 hole gauge cluster and using 4 air gauges (2"diameter, 3 3/4" deep) for my bags, tank and shocks along the bottom. I would cut the 4 to size. Unless there is some air gauges that fit the bottom 4 holes in the '72 (I haven't found yet)
could someone measure theirs to see if this is possible, or does someone know of any reason why this can't be done? thx, Al
1972 GMC Sierra 1972 GMC Super Custom Suburban Last edited by IAFF2407; 03-27-2008 at 10:53 AM. |
03-27-2008, 05:41 PM | #2 |
More Cowbell....
Re: 3 hole gauge cluster help
The dash hole is the same no matter if you have 3 gauge or 7.
And stock ones along the bottom of a 7-gauge cluster are 2-5/8" (I believe). Don't worry, someone will correct me if I am wrong. I KNOW they are larger than 2". And depth is not an issue. As long as they don't hit the firewall, you are good. If you try mounting your air gauges from behind, you may be able to use a stock 7-hole bezel. Just a thought.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
03-27-2008, 07:39 PM | #3 |
These are 2" sunpro gauges. The hole was 2".
Careful where you drill the holes and be careful when tightening the gauges down, it's EASY to crack these things.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 03-27-2008 at 07:41 PM. |
05-20-2008, 03:26 AM | #4 |
5" for top 2.....2 5/8" for the bottoms.....
so what is the size of the center hole? (Im not at my truck or I'd measure)... thanks |
05-20-2008, 04:01 AM | #5 |
its all about the +6 inches
C/40 and bigger trucks had an air guage if the truck had air brakes. This is one I cleaned up and sold on here 5 or 6 years ago... bummer I can't find the after photos... it looked killer.
