03-28-2008, 05:46 AM | #1 |
Gettin By on Gettin By
Dash light relay? How to keep them bright??
Well i finally got Whitey all wired up and running. While fine tuning tonight i noticed the light grow brighter the higher RPMs.
Anyone try to run a relay or direct run the lights to keep them bright all the time?? I'm figuring on rigging up a head light relay, will this help?? It should shouldn't it?? ttt |
03-28-2008, 05:58 AM | #2 |
Re: Dash light relay? How to keep them bright??
Heck I'm still trying to get one light to come on...good luck...
03-28-2008, 06:13 AM | #3 |
Well i've got all the lights on. Seems some of these bulbs will burn out after 30 years or so.
Maybe a capasitor or something. Hold the voltage inline like a vacume box. If i knew any better i'd be doing better. |
03-28-2008, 06:38 AM | #4 |
here's a link for you http://67-72chevytrucks.com/vboard/s...=119379&page=2
Trueman Last edited by 463; 03-28-2008 at 06:39 AM. |
03-28-2008, 07:20 AM | #5 |
I'm running an intrernal alt.
03-28-2008, 07:38 AM | #6 |
a relay won't help this because it is still getting power from the alt. which is supplying slightly varying voltages at different RPMs
03-28-2008, 07:49 AM | #7 |
here is a link for head light relay install http://www.6066gmcguy.org/HeadLights.htm
Trueman |
03-28-2008, 03:22 PM | #8 |
install LEDs in the dash.....
1997 GMC Sierra Ext 1965 Mustang |
03-28-2008, 06:50 PM | #9 |
Leds are a good idea. I'll look into it.
Anyone ever run some sort of rig to stabilize the dash lights?? |
03-28-2008, 11:08 PM | #10 |
Yes, its called a Hi-Output internally regulated alternator.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
03-28-2008, 11:23 PM | #11 |
Ahh.... thanks
03-28-2008, 11:47 PM | #12 |
Hey, GM didn't go overboard with their spending on these trucks just enough to get by and barely that. That and mechanical voltage regulators and you get dim lights and fluctations at low RPM. Thats why so many of us upgrade to a higher output internally regulated (read electronically regulated) alternator, bigger wires (most of my engine compartment is rerouted\rewired) and relays on all the higher powered items. Dash lights don't draw enough power to benefit from a relay.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI Last edited by neonlarry; 03-28-2008 at 11:49 PM. |
