Old 03-28-2008, 06:33 PM   #1
BraveDave
Trans leaking
My '72 is leaking trans fluid where the speedo cable attaches. I took it to the shop and they said there's really nothing they can do to fix it...that's just the way it's designed. I find this a little hard to believe. Anyone know how to fix the problem?
Brave Dave
'72 Chevy Cheyenne Super, '56 Chevy Bel Air,'56 Chevy Nomad, '61 Chevy Impala, '64 Cadillac Fleetwood, 1966 Thunderbird Convertible
BraveDave is offline   Reply With Quote
Old 03-28-2008, 06:42 PM   #2
AGRV8D
Regular Confuser
AGRV8D's Avatar
Re: Trans leaking
you live in Magnolia, there is a guy in Tomball that owns a performance shop called Pavlock Performance.
www.pavlockperformance.com
Bryan is a helluva guy and if nobody offers up any info here, drop by there, and he may be able to give you a hand.
My Stuff
Surgeon General never said anything about smokin' Fords.
Build Thread
AGRV8D is offline   Reply With Quote
Old 03-28-2008, 07:04 PM   #3
Ole Blue 68
Ole Blue 68's Avatar
Re: Trans leaking
This may seem dumb but have you tried some teflon tape on the threads?
Ole Blue 68 is offline   Reply With Quote
Old 03-28-2008, 07:26 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: Trans leaking
There are no threads, but there is an "0" ring and driven gear that you can replace. You don't say what tranny you have but this should pretty much apply to all. The driven gear wears and will cause a leak around the shaft and the "O" ring on the driven gear housing gets hard and leaks . If your driven gear housing is made out of aluminum you need to replace it with a steel one as they wear on the inside. You can get all of the parts and info here:
http://www.transmissioncenter.net/sp...n_______va.htm
You need to know what color your driven gear is...
LockDoc
Leon
Old 03-28-2008, 08:33 PM   #5
Ole Blue 68
Re: Trans leaking
Learn something new every day. That's why I love this board.
Old 03-28-2008, 09:49 PM   #6
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: Trans leaking
Put a new o ring in there, that will take care of it. I also put an o ring between the speedo cable cap and the speedo cable end...just in case.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 03-28-2008, 09:57 PM   #7
OrangeCrush1970
OrangeCrush1970's Avatar
Re: Trans leaking
mine leaks in the same place! I got up under there and fiddled with it and it spit on me, so I left it alone-
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
Old 03-29-2008, 12:37 AM   #8
BraveDave
Re: Trans leaking
thanks for the help, guys!
