Old 03-30-2008, 11:43 PM   #1
chev74
Addicted to Chevy
chev74's Avatar
tach wiring diagram?
i have recently replaced my original dash with the hard to find tach dash -
there is a 3 prong plug on the back with the wires clipped off (black, borw and pink wires). where do these run to?
pic included:
chev74 is offline   Reply With Quote
Old 03-30-2008, 11:53 PM   #2
chev74
Addicted to Chevy
chev74's Avatar
Re: tach wiring diagram?
also, i have been running a set of sunpro gauges for my temp reading- how does the temp sensor hook up to the cluster? followed the traces and it seems to be a brown wire (if this helps)
Old 03-31-2008, 01:49 AM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
If you take a really close look at the back side of your cluster right where the tach terminals are at you will see the following marks on yours as well......
12V
GND
COIL
As you look at the terminals on the back of the tach, you'll see two (2) side-by-side and a third one below. Going clock-wise from the top most terminal they hook up as follows;
12V switched power
Ground
Tach signal- Run this lead through the firewall directly to the tach lead terminal on the H.E.I. DISTRIBUTOR CAP.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 03-31-2008, 02:04 AM   #4
chev74
Addicted to Chevy
chev74's Avatar
BLE youre the best... im glad someone else besides me spends WAY too much time on here...
Old 03-31-2008, 02:04 AM   #5
chev74
Addicted to Chevy
chev74's Avatar
and in all honesty, i really didnt look closely at it...
Old 03-31-2008, 05:19 AM   #6
tvblazer78
Low & Fast!
tvblazer78's Avatar
Don't fill bad, I did the same thing..
tvblazer78 is offline   Reply With Quote
Old 03-31-2008, 08:11 AM   #7
andresco50
andresco50's Avatar
It's + and - from bat and to the + of the coil!! maybe
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 03-31-2008, 09:01 PM   #8
chev74
Addicted to Chevy
chev74's Avatar
hooked it up - works wonderfully! thanks for all the help again BLE
