Old 03-31-2008, 01:34 AM   #1
tbags
tbags's Avatar
Door Gaps
I am having a hard time lining up my door gaps. it seems as though i am going to have to put washers inbetween the hinge and the door to move the door towards the rear of the cab. is this right? also i was told before by a body guy the first thing you should line up panel wise is the doors. again is this correct? Has anybody had this problem before and can tell me if i am doing the right thing.
taylor
67' C-10 Project Truck
Clinton Township MI
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=287690
tbags is offline   Reply With Quote
Old 03-31-2008, 01:37 AM   #2
Re: Door Gaps
You may. I had to use some spacers/washers with mine. Mostly LOTS of patience.
Old 03-31-2008, 01:53 AM   #3
DMARCUM123
Re: Door Gaps
I put a aftermarket door on a friends truck and the door did'nt have the right gap it fit to close to the front so i made a shim the amount i wanted to move it back to line with the cab and if you put the cowl grill on and bolt it to line with the cab post will help lining the door to get the body lines right.
DMARCUM123 is offline   Reply With Quote
Old 03-31-2008, 03:08 AM   #4
tbags
tbags's Avatar
Re: Door Gaps
Did you start with lining up the doors before the rest of the body panels?
Clinton Township MI
My Build Thread
Old 03-31-2008, 04:10 AM   #5
tbags
tbags's Avatar
Re: Door Gaps
Clinton Township MI
My Build Thread
Old 03-31-2008, 09:27 AM   #6
ed2552
ed2552's Avatar
Re: Door Gaps
Yes, start with the doors, because they line up with the unmoveable cab and then everything else lines up with them,
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-31-2008, 12:14 PM   #7
DMARCUM123
Re: Door Gaps
yell line the doors first like i say use the cowl grille to line the crease on it and the one on the cab and then install the fenders and line the crease on the fender to the door
Old 03-31-2008, 04:25 PM   #8
jdstx
jdstx's Avatar
Re: Door Gaps
I would cut a spacer(s) the size and shape of the hinge surface once the required thickness is determined. That way the contact area is maintained. I have never done this. It just seems right to me, but I tend to over think things. I also have a fuzzy line between brilliance and memory. Have I seen this in someones build thread?
jdstx is offline   Reply With Quote
Old 04-01-2008, 07:50 AM   #9
knsmodels
I make Models
knsmodels's Avatar
Re: Door Gaps
our trucks never had the best door gaps straight from the factory.......I think it would take quite a bit of work to get nice tight gaps.....good luck with the project......
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 03-31-2008, 04:17 PM   #10
tbags
tbags's Avatar
Re: Door Gaps
cool thanks guys. how much of a gap do you have between the door and the rear of the cab? i want the smallest gap possible
Clinton Township MI
My Build Thread
