03-31-2008, 04:44 AM | #1 |
GM ONLY BABY!!!
Need pics of Magnaflow stainless exhaust installed.
I'm currently in the midst of installing the S/S Magnaflow 2.5" exhaust kit on my 72 GMC longbed. I have already done the search and haven't found much info. Does anyone have pics of it installed that they could share real quick? I wish they would mark the pipes like Flowmaster does.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
03-31-2008, 07:52 AM | #2 |
Re: Need pics of Magnaflow stainless exhaust installed.
The most critical parts are:
Don't trim the back of the X (only the front if absolutely necessary). Make sure that the bends that go up behind the crossmember are as far front as possible. This gives best trailing arm clearance, and puts things at the right angle for the midpipes to stay closer to the driveshaft and allows you to make them run paralell to the driveshaft which is also critical. Getting things in line right from this point is the only way it will work, or you'll fight with the shock mounts, and you'll have problems with the mid-pipes trying to angle out in the back where the mufflers bolt on. It's impossible to make it work any other way but getting the mids paralell and as close to the driveshaft as possible, or then you'll find that the tailpipes will interfere with everything. Get those bends up behind the crossmember right, and that will let you set the mid pipes where they MUST be. Did I mention this part was very important I'm still not done messing with mine, but I moved on to something else for now. I'm considering going to some 3 or 3.5" tailpipes because these actually look kinda small |
03-31-2008, 03:08 PM | #3 | |
1997 GMC Sierra Ext 1965 Mustang |
03-31-2008, 03:56 PM | #4 |
thats a coil rear
04-01-2008, 03:56 PM | #5 |
No, the original post......what rear is in it
03-31-2008, 03:57 PM | #6 |
Heres mine but it has a 4 inch spring lift on it so may be of no help. I welded a lot of the pipes and had to fab pieces to connect to the headers.
69 Chevy 4x4 383 Power |
04-01-2008, 11:14 PM | #7 |
GM ONLY BABY!!!
Thanks guys!! It is a leaf spring rear and I finally figured it out and got it installed. The pipes between the X and the mufflers was confusing me.
04-01-2008, 11:43 PM | #8 |
did everything clear the leafs?
04-02-2008, 05:00 AM | #9 |
Phone's ringin Dude.
Got any pics or opinions on this system? I'm really thinking about going this route.
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
04-02-2008, 04:20 PM | #10 |
JimPa's post is of a coil rear. You can tell by the trailing arms and panhard bar.
04-02-2008, 06:06 PM | #11 |
I think we are wanting the info on chevydog66 leaf rear though. Any fitment issues around the leaf springs?
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 04-03-2008 at 12:28 AM. |
04-03-2008, 12:18 AM | #12 |
I don't know if this came with it. It's not much help.
http://www.stylintrucks.com/images/U...s/16643MGF.pdf StylinTrucks.com has them for $529.99. Thats less than what I paid for my last Flowmaster system that lasted two years! http://www.stylintrucks.com/parts.as..._prod_ids=3106
