03-31-2008, 08:33 AM | #1 |
Always wrenching!!
5.3L...... which manifolds???
i just put a 2004 5.3 and 4l60e, i see the 98 camaro manifolds fit. i also see lots of pictures of you guys with the stock truck manifolds. my 2004 tahoe manifolds seem to hit the factory pedistal for the motor mount. i also have c5 vette manifolds. any help would be great!!!!
trying to build this with out spening any money haha!!!! real low budget build. and just another one i took.......
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
03-31-2008, 08:49 AM | #2 |
Re: 5.3L...... which manifolds???
Why is there a quad in the back? You rle like Gen III motors, don't you?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
03-31-2008, 09:06 AM | #3 | |
Always wrenching!!
and, yes! they are the best motor out there!!!
03-31-2008, 09:08 AM | #4 |
My dad's 02 Suburban has the 5.3 and it is a good truck, but is even better with the K&N intake
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A Last edited by ed2552; 03-31-2008 at 09:08 AM. |
03-31-2008, 04:55 PM | #5 |
I am running some from a ls6 from a z06 vette. They look like shorties. Car craft did an article that compared them to long tube headers and they did very well, others will agree that headers with a proper tune will be much better but I am happy with my choice. Stock with a tune I made almost 300 rwhp and 300 rwtq. I am now putting in a larger cam so we will see.
Any of the manifolds will bolt up just getting one to fit is the problem. Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
04-01-2008, 01:02 AM | #6 | |
Always wrenching!!
04-01-2008, 04:09 AM | #7 |
Always wrenching!!
OK!!!! i tried the 2000 camaro manifolds and they also hit the motor mount! what mounts are you guys running?? every manifold i try hits the damn mount. PLEASE HELP............
03-31-2008, 07:04 PM | #8 |
Questionable
'98-00 F-body manifolds. Fit for me without grinding.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
02-18-2013, 06:32 PM | #9 |
02-18-2013, 08:59 PM | #10 |
He used ECE motor mounts and stands.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-31-2008, 09:08 PM | #11 |
Camaro Long tube headers for me
03-31-2008, 09:58 PM | #12 |
Just loves his truck.
looks like a manifold you would put on a BB
Gold 1969 c10 LWB--350 gm crate motor 30"muds on the back...with aluminum rims with black and red Chevy bowtie center caps that look awesome! EAGLE SCOUT FTW!!! |
04-01-2008, 04:13 AM | #13 |
Won't the old style turnback stock 307/350 miss the mount?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
04-01-2008, 04:23 AM | #14 |
Always wrenching!!
with the new 5.3l?? the exhaust ports and bolt pattern arnt the same.
Are most of you guys running aftermarket or diff. year frame side mounts??
04-01-2008, 04:32 AM | #15 |
I didn't know. they fit my Vortex 350 just fine..
04-01-2008, 04:42 AM | #16 |
Always wrenching!!
OHHHHHH, yeah with the vortex they would. the new gen III exhaust ports are more designed like a ford head.
04-01-2008, 04:57 AM | #17 |
That sucks big. Someone should be able to help, has to be a header that would fit your app then.
04-01-2008, 05:03 AM | #18 |
Always wrenching!!
im sure there is, trying to not spend money haha. the driver side truck manifold fits, my need some grinding just for clearance but the passenger is being a b*t*h haha
04-01-2008, 05:05 AM | #19 |
Here's a set of Doug Thorley "proto-type" headers that I'm test fitting on my 69 Suburban (5.3/4L60E). They fit great and should add some decent horsepower. I'll probably run the 98-00 F-body manifolds on my 67 CrewCab since it's not going to be a show truck. I've got an extra set if decide to go that route.
04-01-2008, 05:22 AM | #20 | |
Always wrenching!!
ya Ive got a set of the 00 f-body manifolds. the truck ones fit better then they do. the only difference i see is that you are running different motor mounts. I'm still using the stock frame side mounts. the manifolds are hitting the hump in them.
04-01-2008, 09:16 AM | #21 | |
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
04-01-2008, 10:31 AM | #22 |
Always wrenching!!
thanks for all the help guys!!! I did a lil work to the mount, got the truck manifolds to fit. Not trying to spend alot on this truck, just want a nice driver. i got the maro for show and go. thank again for the all the info.
04-01-2008, 06:34 PM | #23 |
Questionable
I PM'ed the Thorley guy here at the forum what seems like a week ago, and still haven't heard anything back. I don't think they're for sale.
04-02-2008, 02:46 AM | #24 |
04-01-2008, 05:24 AM | #25 |
Those headers look sweet in there HartRod.
