04-01-2008, 03:53 AM | #1 |
Lemme show you something!!
A Couple Hours' in the Driveway.....yeah right!
Let's see- two serp. belts, two alternators, a new radiator, 3-1/2 days, 4 skinned knuckles, multiple trips to Napa and countless colorful adjectives spoken out of frustration and contempt, I finally got the serpentine accessory drive setup on my '67!
Part of the issue was that I did not remove the brackets and whatnot from the donor vehicle (89 S10 w/ 4.3) so all the fasteners were missing....but for $15 bucks including the Alt., W/P, A/C Compressor and all pulley's- I figured I could spend some time rounding up the various nuts, bolts, and studs. I also did not plan ahead and score the SI to CS type alternator conversion harness, until I was a$$ deep into the swap. Furthermore, I did not plan on my screwdriver slipping off the bottom hose clamp and putting a nice gouge in my radiator! One note for those who are contemplating this project....the smog pump delete tensioner is hella-pricey! The only place I could find it was my local stealership.......for $67! The A/C delete was very reasonable from my local Napa @ 28 bucks. Also, if you do run w/o the AC and Smog pump- you will need a Gates Model # K060970 belt (21mm x 2480mm) which is about 4" shorter than the one used w/ AC and Smog pump (stock S10). But now that it's on...I'm happier than a pig in s%*t! One question though- does anybody know which upper radiator hose I need to get so it's routed in front of the alternator and connects to a straight t-stat housing?
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
04-01-2008, 03:59 AM | #2 |
Re: A Couple Hours' in the Driveway.....yeah right!
Did you change the waterpump?
04-01-2008, 04:03 AM | #3 |
Yeah, the setup I got came with the reverse rotation W/P as well as the corresponing fan!
04-01-2008, 04:00 AM | #4 |
Great job, sorry about the rad though. What serp setup did you get? My son used a 360 degree swivel thermostat housing that pointed slightly higher up. Not sure if he replaced the hose w/ a different one though.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
04-01-2008, 04:07 AM | #5 | |
I will definately check out the swivel t-stat housings and see if that will alleviate the hose to alternator pulley clearance issues. IIRC they later model Chevy trucks have the upper hose routed in front of the alternator and above the fan. I'm just not sure what years' this was on.
04-01-2008, 04:15 AM | #6 | |
04-01-2008, 04:17 AM | #7 |
Get someone you know to pop their hood on their truck that has a later model vortex. Might be the one you can use??
04-01-2008, 04:19 AM | #8 |
Now you need a cover for your radiator..Why GM didn't make one for our trucks in the beginning huh?
04-01-2008, 04:32 AM | #9 |
Oilfield Trash
What did you use for your power steering pump
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
04-01-2008, 04:47 AM | #10 |
I used the PS pump from the S10. My old '67 pump has a threaded fitting on the back that I had to take off and put on the new pump- in order to use my original hoses. (The S10 hoses won't fit with the older gearbox.) If you go this route- make sure to take the plunger and spring out of the old pump as well so that you get the correct line pressure.
04-01-2008, 06:00 AM | #11 |
Out of the carpool lane.
So would you inform an uninformed individual what the purpose of this is for?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
04-01-2008, 06:07 AM | #12 |
its all about the +6 inches
brad, the serp belt takes less power to run, and with the preset belt tension given by the tensoner (as opposed to the tension put on by you with a long screwdriver when tightening the alt bolts) bearing lifespan in the alt/water pump/steering pump will last virtually forever.
Some thinks it looks better too, but I think the V belt set up is less cluttered looking myself. |
04-01-2008, 06:10 AM | #13 |
Thanks Andy. I guess I'll be subscribing to this for a future project on my new truck.
04-01-2008, 06:35 AM | #14 |
new truck???
04-01-2008, 06:39 AM | #15 |
wher did you get the S1 to Cs conversion harness. i have a zz4 turn key motor and i think i will need one.the 72 will be back from the painter in about 2 weeks
04-01-2008, 07:10 AM | #16 |
NAPA can special order one- it's Eckland or Echler (I don't remember) Part # EC82. However, I couldn't wait the 7-10 days it would take to get it in, so I called an Auto Electric and Battery outfit in the closest full-service town (about 35 miles away) and they had one on the shelf. It's made by PICO and the part number is- 5327C
04-01-2008, 07:18 AM | #17 |
Looks good, I am sure it will be worth the adjectives you used.
04-01-2008, 10:07 AM | #18 |
Gone to greener pastures
Looks good.
Here's a little "rule of thumb" I use when figuring out how long I have to work on something. I look at the project and mentally figure out in my head how long it will take. Then I double the number and go to the next larger time period. For example: I look at a job and figure "15 minutes." Going by my above calculator, I double the number to 30, and go to the next larger time period, hour. And voila, 30 hours. If things go really well, I can get it done in that time frame.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
04-01-2008, 11:32 AM | #19 | |
I bought a 'new' truck about 2 months ago. It's still being built. It's my Camaro's fraternal twin.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 04-01-2008 at 11:35 AM. |
04-01-2008, 02:03 PM | #20 |
<------ you found this one?????
04-01-2008, 07:55 PM | #21 |
Well at least after all that B.S. you got a good looking serpentine setup....
What did it all wind up costing you if you don't mind me asking? Last edited by Ole Blue 68; 04-01-2008 at 07:55 PM. |
04-02-2008, 02:15 AM | #22 |
I picked up the brackets, alternator, water pump, a/c compressor, and ps pump off of C/L for $15 (yeah, I know I stole it...but I don't feel guilty for taking advantage of the hillbilly-tweeker I got it from). Being as I don't have A/C (yet) I needed to get the delete pully, which was $28 @ Napa. I also needed the lower idler that replaces the smog pump @ $67 from the stealership. 27 bucks for the belt, about 20 bucks in miscellaneous fasteners and 14 duckets for the alternator conversion plug and it all adds up to about....175 bucks or therebouts- which is hella cheaper than the 800 bucks they want @ GMPP. Mind you I effed up my radiator, but my buddy had a spare which he gave me. I also screwed up an alternator by trying to re-clock the plug position away from the valve cover (all three of the bolts holding the cases together snapped off). Fortunately, I had another one from an Astro van that works just fine.
04-02-2008, 04:51 AM | #23 |
Junior Member
If you could find the correct brackets you can eliminate the need for the smog delete.The drivers side part number is 10118701 and the passenger side is 10118751.I got mine at a local u pull it off a 94 chevy truck for 30.00 bucks and then adapted it to a big block but they will bolt right up to the small blocks.
04-02-2008, 01:28 AM | #24 |
I am a Referee of life.
Dingfodgy,I would like to make your next mod somewhat easier and less expensive.Here is a tip on radiator hoses.Never use a screwdriver,use a nutdriver or 1/4 drive socket and ratchet.They don't seem to gouge radiators so badly.Don't ask how I knoww.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 04-02-2008 at 01:28 AM. |
