Old 04-02-2008, 02:08 AM   #1
CJ5 Convert
CJ5 Convert's Avatar
Driveshaft spline stuck in yoke.
Hey I was just wondering if anyone had an idea of how to free up a drive shaft. It is the stock rear drive shaft and where the splined end goes into the yoke it will not slide. First it was stuck all the way out and I pumped a whole bunch of grease in it. Then I put a small rachet strap on and forced it down. It shot a whole bunch of grease out and now it won't come back up. I don't even know where to start on this any ideas. -Jason
- Jason
Orange Crush - 1969 K5 Blazer CST 4WD MONEY PIT
1975 CJ5 Renegade - Levi's Edition - 304 V8 original paint
CJ5 Convert is offline   Reply With Quote
Old 04-02-2008, 02:50 AM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Driveshaft spline stuck in yoke.
Sounds like it needs to twist the opposite way that jammed it up. Bolt one end back up, and twist the other end till it frees up. It needs a new spline if this works.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 04-02-2008, 05:17 AM   #3
CJ5 Convert
I'm guesing that is not a replacable part? With my luck. What will I have to heplace to make that happen?
- Jason
Old 04-02-2008, 05:27 AM   #4
The grease is making suction is what it sounds like.Heat it up to melt the grease down.If it was tight before you compressed it it is probably twisted and may not seperate.
Old 04-02-2008, 03:33 PM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
If the spline is striped, a driveshaft shop could put a new spline and slider on it for ya.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 04-02-2008, 08:03 PM   #6
cobinder
Everything is work in progress
cobinder's Avatar
Unscrew the zerk and put your air nozzle in the hole, air it up while someone pulls the two apart.
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 04-02-2008, 09:30 PM   #7
1969K10
1969K10's Avatar
get a 3rd person with a base ball mit
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 04-03-2008, 04:04 AM   #8
CJ5 Convert
I got it fixed guys I had ruined the yoke thing that slides over these spines. I got it all ready to put in. It just got fresh spicer u joints and is being rattlecanned black right now. Thanks for all the help, I wouldn't even have know where to start. -Jason
- Jason
Old 04-03-2008, 03:35 PM   #9
OLDCHEV4X4
OLDCHEV4X4's Avatar
Did you get a new slider/yoke?
Did you have to take it to a driveline shop?
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 04-04-2008, 05:13 AM   #10
CJ5 Convert
Yeah I had to get a new slider yoke. It was ruined. They charged me $75 bucks to install and get the new parts.
- Jason
Old 04-05-2008, 10:12 PM   #11
70rs/ss
70rs/ss's Avatar
That was cheap, good luck with the new one.
70rs/ss is offline   Reply With Quote
