Old 04-02-2008, 02:10 AM   #1
cstm68
cstm68's Avatar
weight of a 68 1/2 ton
does anybody know the ballpark waight of a 68 short fleet 2wd with a small block?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 04-02-2008, 02:14 AM   #2
ed2552
ed2552's Avatar
Re: waight of a 68 1/2 ton
What i've heard, about 5300. To know the weight of your truck fo' sho', go to a steel place and put it on the scale, they may charge like $2 because they aren't getting anything in terns of steel, but if they charge anything it will be cheap
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 04-02-2008, 03:55 AM   #3
Huck
Huck's Avatar
The 67-72 2wd trucks tend to go around 4,000 lbs curb weight. A full tank of gas, auto, air, 4x4, long vs short bed can all change the curb weight. A loaded 3/4 ton 4x4 can go 5,000lbs+
Huck is offline   Reply With Quote
Old 04-02-2008, 04:16 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
plan on 4000 pounds.
Old 04-02-2008, 04:20 AM   #5
stllookn
Saving 1 truck at a time!
stllookn's Avatar
GM Restoration Guide lists the CE as 3640 curb weight and the CS as 3495.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 04-02-2008, 04:41 AM   #6
Longhorn Man
while true, those are dry weights, with no options. A tank of fuel, 5 quarts of oil, 2 gallons of coolant, a spare tire, rear bumper, power steering and brakes, A/C reminants... it adds up quick.
Old 04-02-2008, 06:42 AM   #7
sdkid
The grain elevator or the local landfill are where I go to get scaled.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 04-02-2008, 06:51 AM   #8
ed2552
ed2552's Avatar
He was in washington, i don't know what's out there for grain elevators, but i would use my local co-op for my truck, too
Old 04-02-2008, 07:01 AM   #9
67_C-30
I have a radical idea!
67_C-30's Avatar
My '69 C/10 SWD fleet with a 350 and TH350 weighs around 3850#.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 04-02-2008, 08:15 AM   #10
El Jay
Gone to greener pastures
Go to your local quarry.
If you don't need an "official weight" with paper work, they'll usually just let you roll up on the scale & get a weight.
Most of them have a digital, outside display.
Just remember to take a pen & paper so you can write it down.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 04-02-2008, 08:32 AM   #11
69-350
Oil trash and damn proud of it
69-350's Avatar
Weigh scales, too. Usually their scales are just large enough to get all wheels on it. My 72 is 4000-4100lb, without me in it, quarter to half tank of gas, spare tire, rear bumper, no a/c, power steering, with toolbox, and maybe 50 pounds of misc crap in it. According to the scale at the junk/scrapyard I used to work at, so god knows how that scale could have been rigged.
Not as bad as my 97, with gear and tools, it drives everyday at about or a bit above the 6,000lb mark. half ton truck.
Mark
1997 K1500 Z71, 14 bolt SF 3.73 posi, Bright Blue Metallic. 6" Superlift
1972 C-10, toolbox, p/s, 350/TH350/3.73 open, black int., bronze
2008 Dodge MegaCab. H&S tuned 6.7 Cummins. Fast Four Tons
Some of my pics http://s107.photobucket.com/albums/m294/69-350/
69-350 is offline   Reply With Quote
Old 04-02-2008, 09:02 AM   #12
stllookn
stllookn's Avatar
The easiest way here is to go to the transfer station (dump) and they will weigh your truck before and after you dump your garbage...or just charge you $20 for the minimum.
Old 04-02-2008, 02:04 PM   #13
Longhorn Man
truck stops too. Pilot stations are supposed to be real acurate.
Old 02-24-2009, 08:24 PM   #14
exmonkeypunk
Barrito Loco Diablo
exmonkeypunk's Avatar
Re: weight of a 68 1/2 ton
Yikes... I get my tag renewal form in the mail and they have my truck listed as weighing 8000 pounds... Wow. I think there's an error. 72' GMC C/2500 long bed. stock 350.
exmonkeypunk is offline   Reply With Quote
Old 02-24-2009, 08:36 PM   #15
Longhorn Man
thats probably your GVW. The theoretical weight of your truck + full payload.
8000 pounds sounds about right... maybe a bit heavy.
Old 02-24-2009, 08:37 PM   #16
jbristo67
resident oilfield trash
jbristo67's Avatar
My title says 3600
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 02-25-2009, 09:00 AM   #17
68Stepbed
68Stepbed's Avatar
I weighed my stepper just after I put the V8 in a few years back. I had steel rally wheels, oak bed floor, original steel bumpers, drum brakes, and a loaded down tool box in the floor board and mine tipped the scales at CO-OP at 3560 lbs. That's without my big butt in it. With the aluminum wheels, aftermarket bumpers and no tools in the floor, I would guess about 3450 lbs. now on mine.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-25-2009, 09:18 AM   #18
charlie diaz
charlie diaz's Avatar
I just went to the dump the other day, and the scale there said my 69 1/2 ton short wide weighed 3942. It was 39 and some change.
charlie diaz is offline   Reply With Quote
