Old 04-04-2008, 05:02 AM   #1
oldspowered
resto body guy
87 pickup woes!
i have a 1987 1/2 ton TBI 350 chevy pickup and i can't seem to keep taillight fuse not from blowing! i have cleaned the tailight sockets replaced the bulbs and cleaned the grounds. and replace the headlight switch with another one i had. still no luck!
what else is on that circuit?? any ideas help....
Thanks, David
oldspowered is offline   Reply With Quote
Old 04-04-2008, 05:06 AM   #2
71swb4x4
71swb4x4's Avatar
Re: 87 pickup woes!
Check the wires from the housing all the way to the front. There may be a bare spot that is grounding out.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-04-2008, 05:17 AM   #3
f.monroe
f.monroe's Avatar
Re: 87 pickup woes!
I had a truck in high school that did this until it finally got on my nerves to the point I had to do something . I found that the wires were pinched between the frame and the bed . Lifted the bed a little to release the wires , rerouted them , and the problem was taken care of . Once I started looking for the problem , it only took a short time to find the problem . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 04-04-2008, 03:07 PM   #4
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: 87 pickup woes!
Thanks, David
The license plate light is on it, and maybe a trailor plug if your truck is equipped with one.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 04-04-2008, 03:47 PM   #5
slug
slug's Avatar
Re: 87 pickup woes!
the dash lights are alson on that circuit
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
