![]() Join Date: Jan 2006
What size alt?
What size altenator are you running? I need to purchase a new one and was wondering if I should go with more amps. My current alt is 61 amp rating. I don't have air or electric fuel pump or fans. What amperage would you guys reccomend..thanks
#2 | |
Gone to greener pastures
![]() Join Date: May 2007
Re: What size alt?
You now have my .02.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
Lemme show you something!!
Re: What size alt?
Being as you need to replace it anyways I'd go with at least a 100 amp model- you never know what sort of electrical do-dads you'll be inclined to add in the future, but at least you'll know the alt. is up to snuff.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
Re: What size alt?
61A is the largest alternator offered in these trucks and is more than adequate for a loaded truck.It is also the maximum windings that will fit the original case.I found this out when having my alternator built for use with a snow plow.I had the 49A and that highest rating he could get out of it was equal to GM`s 61A.You`d have to go to the later right-side alternator.When converting to the later two wire internal regulator type alternators you`ll most likely be jumping up in amp rating.I ended up using one from a 6.2 diesel which is 100A.
![]() Join Date: Jul 2004
Re: What size alt?
Just my personal opinion, but I would not go larger that around 60 amps or so because the wire to the battery is only 12 ga. If you had a really low battery I suspect a 100 amp charge would fry the wire or the fusable link (16 ga) that is supposed to be in there just before the battery.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
