04-04-2008, 11:19 PM | #1 |
180 or 195 thermostat?
Which is better for a "69 350 auto, 180 or 195 thermostat(or what was stock)? Thanks for any comments.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter |
04-04-2008, 11:44 PM | #2 |
Truck and auto performance nut
Re: 180 or 195 thermostat?
I prefer a high flow 180.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
04-05-2008, 12:20 AM | #3 |
I agree, 180.
Rob |
04-05-2008, 01:04 AM | #4 |
Depends what you're looking for...I run a 180 but if you're hoping to improve MPG you might want to consider going higher.
04-05-2008, 01:32 AM | #5 |
There really isnt a right answer, more of a preference thing. The important thing is that it climbs to the temp that it opens and then stays there.
I use a 195 in the winter for extra heat from the heater, and 180 in the summer.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
04-05-2008, 05:47 PM | #7 |
I agree with the 180....195 is for newer motors that run hotter. The guy that built my motor said go 180 so that when it runs hot in the summer it doesn't go past 200. He said the motor will last longer that way.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
04-07-2008, 07:44 AM | #8 |
04-07-2008, 07:52 AM | #9 |
i run a 160, it still climbs up to 180-190 sitting in traffic.
04-07-2008, 04:59 PM | #10 |
laying low
I think whatever temp stat you're running the engine needs to be tuned for that temp range to get the most power and mileage out of it.
After some extended running look at the plugs and see if they're running clean or sooting up a bit. Running too rich or lean affects the running temp too. Ignition timing also affects running temp.
04-05-2008, 03:33 AM | #11 |
I run 180 to play it safe.195 leaves little margin to boiling point for me.
04-05-2008, 03:37 AM | #12 |
Gone to greener pastures
I run a 180, but I don't think it matters a whole lot.
The thermostat controls the minimum temperature. If the engine has the tendency to run over 195, it's going to run over 195, regardless of the thermostat.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
04-05-2008, 05:04 PM | #13 |
I have a 195 in mine but I don't remember the reasoning for it at that time.
Save your money and do it right the first time. 1968 GMC short bed 1972 Cab 74 SB Chevy running gear |
04-05-2008, 05:27 PM | #14 |
Old member
The motor has a lot to do with what you run.
For instance is it fuel injected? If so then 195 Carburated 180 Computer cars run hotter temps so a higher thermastat is recomended by most. If you run a lower thermastat it can play hell on the computer trying to compensate for it. Does the engine run cool in traffic? Then 195 would be OK in the summer & winter you get the heat out of it. If it doesn't then run the 180.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-07-2008, 04:38 AM | #15 |
what does the Factory Manual say for 350s? For BB it's 195
04-07-2008, 06:17 PM | #16 |
Surely if GM says 195 then they must be on to something. If everything is working right, it won't boil over. This is true even if it's 210 degrees. Boiling is 212 plus whatever the antifreeze raises it to. Gotta remember antifreeze works in both directions high and low.
04-07-2008, 10:24 PM | #17 |
I prefer to runa 180 on the older engines (pre '80s) because I don't feel there is a real need for the extra 15 degrees of heat in Texas weather. I run a mechanical temp gauge and with the 195 stat I'd see temps up to 220* or so just a few minutes after shutting the truck off. With a 180, it doesn't get over 200* after shutting it off.
