Old 04-06-2008, 04:12 AM   #1
into69z
"brand new second-hand"
into69z's Avatar
Cool a/c fan switch problem-
Once again, I must return to the masters of these fine trucks for some sound advise and shared wisedom! I read recently where someone had a problem with the fan control switch-it would go low, then medium, then back to low-but not high. Can anyone remember the fix? I put in a fresh switch-just r & r'd the heater core -cleaned the evaporater and detailed everything associated with the a/c-heating system. Just can't get the fan to blow on high. I did try the fan directly to the battery prior to install and it turns lots of rpm's hooked directly. This problem did exsist before I started on the project( that's why I had a new Idack switch.....any bells ringing??? help.....Steve
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 04-06-2008, 04:39 AM   #2
haysonj
haysonj's Avatar
Re: a/c fan switch problem-
There is a relay on top of the heater box that is probably your problem. It also has a ground that goes from it to the fan motor and a ground that goes from the fan motor to the cowl.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 04-06-2008, 05:09 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yep, more likely than not, this is the problem
Old 04-06-2008, 05:23 AM   #4
into69z
into69z's Avatar
I knew you guys had the answer! Thank You Haysonj-i'll get at it in the morning.
Steve
67 Camaro
96 Impala ss-sold
b69:
