Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 04-06-2008, 09:33 AM   #1
Zonaman
Zonaman's Avatar
67-72 Door: Friction Pads
There are some excellent door rebuilding FAQ's posted on replacing vent windows and regulators. As long as you're in there, why not repalce those worn friction pads? Here's a few tips that I hope will take the mystery out of this job:
Friction Pads:
These are the little goobers that are sandwiched around the stop on the top hinge:
First, there's a roll pin that you can knock out with a punch and some WD-40.
Once the pin is out, swing the stop free...
and slide the stop out through the inside of the door.
The old pads can be removed from the opening.
contiuned...
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline
Old 04-06-2008, 09:46 AM   #2
Zonaman
Zonaman's Avatar
Re: 67-72 Door: Friction Pads
Rebuild kits are available; some assembly required.
Size:  30.8 KB Name:  IMG_0073.JPG
Installation is pretty much the reverse. Don't forget to clean all the crud off the stop! You'll note that the stop won't slide in over the new pads with the ease it did over the old ones- a healthy sign! Just tap 'em in with a hammer till it's fully extended, line up the holes, and secure the roll pin.
This simple repair will control door swing and save your hinges and pillars too!
Zonaman is offline
Old 10-23-2008, 04:39 PM   #3
tumbleweed68
where did you get the rebuild kit?? Mine needs it and i don't really want to take the doors off. Thanks
tumbleweed68 is offline
Old 11-23-2008, 10:04 PM   #4
Zonaman
Zonaman's Avatar
Sorry to take so long answering. I've been busy and not able to spend much time on the forum. I ordered mine from ClassicTruck Parts.
Hope this helps
Zonaman is offline
Old 11-23-2008, 11:20 PM   #5
suville
suville's Avatar
$34.95 for the stop kit $38.95 for a whole new hinge dont seem cost effective!
suville is offline
Old 03-02-2009, 09:32 PM   #6
gumbudah
I was thinkin that was a bit steep as well. I'm betting a guy could take the old ones out, then find some material that would work and reline your existing pads... I just havn't figured out what would work yet...? Leather? Nylon cutting board material??
gumbudah is offline
Old 05-16-2009, 09:38 PM   #7
Zonaman
Zonaman's Avatar
Kit does both doors so that's $35 as compared to almost $80 and if your hinges are otherwise intack, why go through that alignment ritual? But I know guys who've fashioned them form old disc brake pads for even more savings.
Zonaman is offline
Old 03-02-2009, 10:16 PM   #8
Sammy
Too bad you couldn't use a front brake disk pad from an old one and shoot counter sunk rivets into it.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline
Old 03-11-2009, 12:55 PM   #9
gumbudah
I just had a bit of a revelation on this one. My pads are about 50% worn through. I've been trying to think of a material I could use to replace them with, but I just came up with the idea of flipping them over! That would leave a gap on the back side, but I'm thinking about $4 worth of two part epoxy or jb weld could fill that contour back in.
gumbudah is offline
Old 04-22-2009, 10:54 PM   #10
Critter
Future TOTM Winner
Critter's Avatar
I haven't done this personally but after reading this, could they be shimmed in a way that make them thicker again? Just a thought...
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline
Closed Thread
