04-06-2008, 06:15 PM | #1 |
Chasin' the Dream
Electric coolant fan wiring relay
I got my fan installed and wired up according to the kit manufacturer specs I got from the parts store. All went well, temp stayed normal, until I went to turn the truck off. Now there is like a 2 second delay from the time I turn the key off til the engine turns off. Its not dieseling, it just stays running for a bit, then shuts down.
Is this because there is no relay? I have a relay that came with the (used) fan but I wasn't sure where in the circuit to put it. Jerry |
04-06-2008, 06:44 PM | #2 |
Re: Electric coolant fan wiring relay
Your fan is acting as a generator while it is turning after you turn the switch off thereby adding a small amount of current to the system. When it stops turning, engine dies. Add a one way diode in the power wire to fan or add the relay.(between switch and fan)
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer Last edited by jhow66; 04-06-2008 at 06:45 PM. Reason: spelling |
04-06-2008, 09:52 PM | #3 |
its all about the +6 inches
I would never even consider running a fan like that with no relay.
Jhow is 100% right though, the fan is acting as a generator and making enough power that it back feeds through the system and triggers spark to keep the engine running. |
04-06-2008, 11:28 PM | #4 | |
Chasin' the Dream
Thank you, jhow, for confirming my suspicions. I was pretty sure that a relay was needed, I just wasn't sure where in the circuit to put it. |
04-06-2008, 11:34 PM | #5 | |
Anyway, ya a relay would help.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
04-06-2008, 11:40 PM | #6 |
Green club
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
04-07-2008, 03:33 AM | #7 | |
Chasin' the Dream
True pcmcobra, I was not 'belittled' as nothing was said against me.
