4x4 transfer case shift decal location.
I have seen the transfer case shift pattern on the glove box and my 69 had it on the cieling ( inside of roof_) ..... what is correct? and where?
Also how about the locking hub sticker?
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
Re: 4x4 transfer case shift decal location.
Locking hub sticker on my 67 is on the glove box door (i think), and the pattern is on the passenger roof (for sure), 69 may be different
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A Last edited by ed2552; 04-07-2008 at 06:34 AM. |
SWB 4x4 Collector
![]() Join Date: Jun 2001
I think it just depends on the factory where they put the sticker. Both are correct, but for you, if it was between the two visors, I would put it back there. I believe those two spots to be correct though. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
This is on my 69 K10.
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
Don`t put those stickers on there!!It will increase the value to at least double!J/K!!!!!
#6 | |
![]() ![]() Quote:
any chance the location had to do with the type of X-fer? the pic shown is the shift pattern for a T-221. I've never seen a truck with the shift pattern sticker in it, but that's not saying much.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
SWB 4x4 Collector
I don't know if there is really a true answer to this, but I would believe more on what factory these trucks came from as a possibility. I have a 1970 chevelle as well, and even like buildsheets ended up in about the same spots from the same plant, but were way different in other plant locations, even not even putting them in. This leads me to believe that it just depended on that shift's worker who put the stickers in that location but at another plant they would put them in a different spot. I know that there are shift pattern decals with np205's as well, but most didn't come with them because of the shift pattern on the knob unlike the 67-68-possibly 69'? Trevor
SWB 4X4 CLUB
My 68 has a rockwell transfercase and the sticker is between the sunvisors.
Jason |
