Old 04-07-2008, 07:20 PM   #1
crasten123
crasten123's Avatar
Driveshaft Bearing Question
Hello,
I've just lowered my 72 SWB fleetside (4.5/6) and noticed when accelerating the truck vibrates a bit. Could this be a problem with the driveshaft angle, as well as the center driveline bearing? Anyone experience this problem? Has anyone changed their driveline bearing to the newer polyurathane bearing by CPP?
Ct
crasten123 is offline   Reply With Quote
Old 04-07-2008, 09:25 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Driveshaft Bearing Question
is the shaft phased properly?
Old 04-07-2008, 09:53 PM   #3
crasten123
crasten123's Avatar
Sorry, not sure what that means?
Old 04-07-2008, 11:45 PM   #4
eric67m
eric67m's Avatar
Do you need to phase all 2 piece driveshafts? My 67 K10 has a 2 piece drive shaft. It is a corse spline (manual transmission) and if I rotate it 4 splines like the Haynes manual says it is basically rotated 180 deg IIRC.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 04-08-2008, 12:52 AM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
all 2+ piece driveshafts have to be put together the same way they were ballanced or they WILL vibrate. but if all you did was lower it, the rear driveshaft may be bottomed out/too short. the factory style carrier bearing is a good design/exelent with a little bracing.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-08-2008, 04:20 AM   #6
Longhorn Man
I can't explain it... when you slide the second shaft onto the first, you have to make sure the ears are in line with each other.
Old 04-08-2008, 07:29 AM   #7
eric67m
eric67m's Avatar
Thats what I always thought was funny. My Haynes manual says to line them up and then rotate the rear shaft 4 splines to the left. From what I remember it is 180 deg off from where you started. I have never had any vibrations but have plenty of slop. Im not sure if my slop is the slip joint or the trans/transfer connector. I just never figured out the phasing or had any problems on my 4x4. I kind of assumed it was a auto tranny fine spline thing?
Old 04-08-2008, 12:30 PM   #8
Longhorn Man
wow... never heard of that one.
Old 04-08-2008, 01:32 PM   #9
neonlarry
neonlarry's Avatar
You said you just lowered it 6", did you put in an adjustable track bar? If not your driveshaft angle is probably of to the side and that could be causing your problem.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 04-09-2008, 06:20 AM   #10
crasten123
crasten123's Avatar
I do have an adjustable traction bar that I installed. I will double check to see if the rearend is centered correctly.
Old 04-09-2008, 10:14 PM   #11
neonlarry
neonlarry's Avatar
Traction bar or panhard bar?
Also I have been using the poly carrier bearing (from inline drive) for a few years, factory replacements would only last me a few months.
Old 04-10-2008, 12:48 AM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Traction Bar is not the same as a Panhard Rod. One panhard rod keeps the rear end in place from side-to-side. Traction bars are located on each side of the rear end and their intent is to maintain traction under "hard" acceleration conditions. A coil spring rear end will need a panhard rod, but it may not need traction bars. Leaf spring rearends don't use panhard rods, but may need traction bars.
Member Nr. 2770
Old 04-10-2008, 12:55 AM   #13
70 longbed
neon larry,
Looking for a website for inline drive. It did not come up on google; can you help me out?
Keith
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 04-10-2008, 03:46 AM   #14
neonlarry
neonlarry's Avatar
My bad its inland empire:
http://www.iedls.com/bearings.html
Old 04-10-2008, 07:20 AM   #15
crasten123
crasten123's Avatar
i did install a panhard bar from cpp (my mistake). It sounds like its best to change the center bearing to the newer polyuretane version. Also, I may need to center the rearend since its lowered. Is there a technique to centering the rearend?
