04-08-2008, 03:06 AM | #1 |
pretty dissapointed. (track results)
pass 1
60' 2.413 330 6.139 mph 60.28 1/8 9.661 mph 61.29 was spitting and popping let out of it. pass 2 60' 2.207 330 5.935 mph 61.51 1/8 9.012 mph 77.28 pass 3 60' 2.218 330 5.884 mph 62.30 1/8 8.943 mph 77.54 truck has 468 bbc, turbo 400, ladder bars with coil overs, 9 inch ford with 4:56 gears, 33 inch mickey thompson sportsmans. it would spin pretty hard out of the hole. left foot braking about 2000 rpm. was hoping for low 8s any one have any suggestions. |
04-08-2008, 03:31 AM | #2 |
Re: pretty dissapointed. (track results)
First you need to get it to hook up. Those MT sportsman tires do not work well.
Check the tune up. It seems to be really down on power. Make sure the plugs and wires are good along with the cap. Make sure you have the firing order correct. What is your timing? What kind of converter? What's your engine combo? A bad day of racing is still better than a good day at work
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
04-08-2008, 03:51 AM | #3 |
its a 468 bbc turbo 400 2500 stall, 4:56 gears, spool, ford 9", ladder bars w coil overs. 2 runs it ran fine just spinning bad. went around water box backed up did short burn out.
also i noticed the trans shifted automaticlly a couple times. timing is locked @ 34 degrees. |
04-08-2008, 05:47 AM | #4 |
What cam and heads are you running? What carburetor do you have? What RPM do you shift at? Did you let some air out of the tires to try and make it hook off the line?
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive Interior 1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories My momma took me off the bottle years ago..... |
04-08-2008, 07:09 AM | #5 | |
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 04-08-2008 at 07:10 AM. |
04-08-2008, 08:52 AM | #6 |
Hay Team!!
Give me the specs on your engine, you might just need some "tuning"
I have a pretty stock 468 running 7.90's on motor with 4.10 gears. And I am LWB...!! As far as hooking, that is a different issue but lets get some better times. Surely, you should be well out of the 9's in the 1/8
1972 Chevrolet Cheyenne LWB "Orange and White" 8) |
04-08-2008, 11:37 PM | #7 |
well as far as specs on the engine i don't have any. when i got the engine it was complete with a bent push rod. the guy said he ran it a month around town and push rod bent so he yanked it out and went back with small block. i know its got a solid lift cam from what he said not really sure what to set the valves at. i reset all the valves at .021 just to see if it would hold up i think he let rockers get loose and push rod came out.
i let tire pressure down to 8 psi. timing is locked @ 34, mechanical and vacum disabled 750 demon double pumper steel heads (oval port) edelbrock torquer II intake 1 3/4 long tube headers, 3 inch exhasut dynomax race mufflers i know for a fact i need some plug wires, not arcing but just junk wires |
04-08-2008, 11:42 PM | #8 |
heres the exhaust
04-09-2008, 12:37 AM | #9 |
More timing (somewhere around 38 as long as the fuel is good) will make the engine run harder on top. With that said, you really need to know what cam you have before trying to turn it that tight. When you shift @5500 RPM is that because the motor quits pulling? Have you run a compression check on the motor?
04-08-2008, 11:40 PM | #10 |
was shifting 5-5500
04-09-2008, 01:00 AM | #11 |
no i havent yet it seems to be running fine so i havent tried that yet. but now that u say that i have been fighting a problem with blow by as u can see by looking at first pic in post 7, oil was dripping out of breather onto header. i made a baffle to stop it
04-09-2008, 01:22 AM | #12 |
i did ck exhaust temp at each header tube and noiced cylinders 5,7 100-150 degrees lower than the rest.
but like i said the wires are junk could be a problem. also what plugs are yall using in ur big blocks |
04-09-2008, 01:37 AM | #13 |
I run NGK UR5's on my street truck (468) and Champion Race plugs (can't remember the number) in the 396 for the track. Also, the Bosch Super's from Autozone work surprisingly well. MSD now has a line of wires out that are considerably cheaper ($45 or so a set-build your own wires). I'm running those on my 468 with now problems. Sounds like a compression check is due of the engine has a bunch of blow by. It could be rings, but Big Block Chevy have a bad habit of chewing Valve Guides which will make it use oil and have low compression.
04-09-2008, 05:54 AM | #14 |
Hay Team!!
Yep...start from scratch and check your tune. Start with a compression check. Bump your timing up to 38 degrees full advance as already mentioned.
Has the carb been tuned in? Those demons don't make the power they should right out of the box...you have to tinker with them. I pulled a demon out of the box and bolted it on....noticed a hesitation and tuned the whole thing in.....I picked up about a half a second!
1972 Chevrolet Cheyenne LWB "Orange and White" 8) Last edited by Outlaw72; 04-09-2008 at 05:55 AM. |
04-09-2008, 06:04 AM | #15 |
not much of carb tuner i can get it to idle and run decent but not to sure about jets. pulled plugs and they looked pretty good.
04-09-2008, 06:12 AM | #16 |
Hay Team!!
Also, food for thought......a 750 was too small for my engine. It would give a lean pop and hesitation at about 5500 rpm. I slapped an 830 hp on it and also a demon 850. World of difference. Now I shift it at 6k-6200 on the bottle. I am almost certain that carb is too small.....it might seem fine just cruising around but it will more than likeley bang out high in the rpm range. Looks like you just need some good old fasshoned tuning......I run an NGK #8 plug....mine likes those much much better than the R45 delco plugs.
04-09-2008, 06:23 AM | #17 |
damn no money for carb right now hopefully i can find some other problem.i know it has suspension problem i felt it hop a little and spinnin pretty bad
04-09-2008, 06:31 AM | #18 |
Make sure the rear shocks are in good shape. No need for any drag type shocks, just a good working stock type. Also, checking all of the suspension for bind or free movement is essential. Even though those MT Sportsman's have a large contact patch, their not known for hooking really well.
04-09-2008, 06:38 AM | #19 |
yeah ive heard they dont hook well but my uncle had them on his 55 with same suspenion and pretty much same engine in high 7s but that was 10 years or so maybe the material went down hill since then.
04-09-2008, 02:47 PM | #20 |
I had decent luck with sportsman pro's on a 13.5 second street truck.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
04-09-2008, 05:09 PM | #21 | |
"Sportsman offers an adhesive yet long wearing tread compound and rigid sidewalls making this the perfect tire for ''drivers''. Inner tubes are recommended to maintain proper inflation (except #672-1557)" "Sportsman Pro" A two-ply sidewall wrinkles like a drag slick, while still providing a street legal tread design. Ultra soft compound insures plenty of off-the-line bite. Inner tubes recommended."
04-09-2008, 08:54 PM | #22 |
i had the sportsmans on mine and they wouldnt hook for nothin then i went to the et streets and what a difference they hook so well i would recomend them to any street strip car or truck.
04-10-2008, 01:19 AM | #23 |
i think i may be on to something. not sure if it will solve problem all together but it may help.
was looking at truck and tried to bounce it in rear and it took both hands and some A$$ so i checked my uncles 55 truck and i could easily bounce it with one hand. not to sure which truck is correct his is just sitting but two different people did the backhalfes. how can i find correct spring rate for my truck. what springs are some of yall using? |
04-10-2008, 01:52 AM | #24 |
talked to a tech guy at s&w race cars he said 170 springs way to stiff need to go with some 130s.
guess i will try that and post some results |
04-10-2008, 02:43 AM | #25 |
130's are to light unless you are only 600lbs on the rear....IMO
I am 1400 on ther rear...subtract the unsprung weight and I'm at 1000lbs. I run 170lb springs and they compress 3 inches with the weight of the truck on them.
