PITbut
Rubbing panels. (non-perv)
What do you guys do about the panels that rub against other panels. Like the fenderwells where they are bolted to the fenders.. Thats just a matter of time before that gets metal to metal and starts rusting....
What do you guys do with those areas when reassembling? Do you do anything special there??? |
Active Member
![]() Join Date: Jul 2007
Re: Rubbing panels. (non-perv)
I took the fender wells of my 69 Chevy couple of months ago and noticed some rust buildup but it wasn't too bad after about 15 years when I had them off the first time. Fortunately I'm not in the "salt on the streets" belt here in Texas.
Not sure what a person can do other than sand the mating surfaces real good and paint them with a good type of rust preventative paint. Moisture and dirt grime will creep into those crevices no matter what you do, though. I suppose a person could use some sealant in there. |
#3 | |
PITbut
#4 | |
Active Member
Most of the really bad rust that I've noticed on the inner fenders has been towards the front under the battery area. I use a plastic battery protector on my trucks like the ones used on boats but without the lids. http://www.academy.com/index.php?pag...rine/batteries |
Under Construction
check with your local paint supply store. I know my buddy used a clear plastic adhesive tape made specifically for this on my 56. I have also seen him use the soft side of the adhesive velcro for this as well.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Luv the Crewcabs
Maybe try some Welting like the older Trucks Used?? Let us know what you end up using, I will need to do it to the 67 once i get it ready for paint............
Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
![]() Join Date: Nov 2004
Tighten the crap out of your front clip. It shouldn't move very much at all. You're "over imagining" how much the body parts flex
![]() I used fender welting on my rear step fenders.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
