04-11-2008, 08:09 AM | #1 |
new engine YAY! cam help anyone?
well i just purchased a new to me enginge from a friends dad its a 350 4 bolt main out of a 75 chevy originaly but it was made into a crate engine by some company sometime in its life
its a great running engine but it is good need of a rebuild i got the whole thing for 100 bucks which i thought was a pretty good deal im hoping to get into a parts store saturday before i work and get a gasket set and a set of freeze plugs and i know the heads need new valve guides so im gonna have napa or someone redo my heads for me and im puttin new rings in tomorow and this is where i run into a question about the cam i want to buy a cam/ lifter combo for the engine its just gonna be a work horse engine it will probly spend most of its life being a daily driver and pulling new cars and trucks home behind my 68 c/20 anyone got any ideas on a good affordable cam lifter kit that would get that job done well?
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) Last edited by drivethechevy; 04-11-2008 at 08:09 AM. |
04-11-2008, 10:02 AM | #2 |
Re: new engine YAY! cam help anyone?
somethin like this should make you happy
Summit # CL12-210-2 Basic Operating RPM Range: 1,500-5,500 Intake Duration at 050 inch Lift: 218 Exhaust Duration at 050 inch Lift: 218 Duration at 050 inch Lift: 218 int./218 exh. Advertised Intake Duration: 268 Advertised Exhaust Duration: 268 Advertised Duration: 268 int./268 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.454 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.454 in. Valve Lift with Factory Rocker Arm Ratio: 0.454 int./0.454 exh. lift Lobe Separation (degrees): 110 Intake Valve Lash: 0.000 in. Exhaust Valve Lash: 0.000 in. Grind Number: CS 268H-10 It'll be quite a bit healthier than stock, still work well with stock heads, idle decent with a little growl, provide enough vaccum, and get decent MPG. All strictly my opinion. Im sure you'll get many.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
