I am trynig to figure out what lug nuts to use on my 68 2500 GMC to mount aluminum slots. What is the thread pattern on my truck? Not sure how to figure this out or where to buy em. I looked at Napa and Pepboys out of convienence and they didn't have enough lug nuts even if I could have figured out what lug to use.
Re: Lugs nuts to mount slots on my 2500??
They should be 1/2" fine but they might be 9/16" fine not sure what year they went to 9/16". You probably need the ones with the long shank. The one where part of the lugnut rides in the bolt hole. Unilug style. And you'll probably need some washers. You should be a able to buy a set with everything. Maybe Mr. Gasket. Basically what you want is the shank part as thick as the wheel.
its all about the +6 inches
1/2 inch... 9/16 came in 71 wih the disk brakes.
Trucks N Tranzams
You can get them here. He is a great guy and has very fast shipping.
http://stores.ebay.com/TorqueThrust-...QQftidZ2QQtZkm
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
thanks. will post a pic when the slots are mounted up.
