Old 04-13-2008, 05:55 PM   #1
Storm Chaser
Storm Chaser's Avatar
52" LLC question... help!
OK, I've been searching all over for the answer to this question, but I can't find it... The question concerns swapping to the 52" springs (using rear springs in the front). All the brackets are no problem, but what do you do at the axle? The longer leaf springs are 2-1/2 inches wide, where the springs coming out were 3 inches wide. Do you just mount it up with the plates from the original springs, even though there is a 1/2 inch difference (especially since you can't change the perch on the passenger side, being that it is cast into the housing).
What's the proper way to connect the front end to the 2-1/2 springs?
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 04-14-2008, 07:39 PM   #2
Storm Chaser
Re: 52" LLC question... help!
No one's done the long leaf conversion?
1988 R2500 Crew Cab
Future plans-
Old 04-14-2008, 08:07 PM   #3
vern350
like a rock
vern350's Avatar
maybe this will help? ..... http://www.coloradok5.com/52inchspringswap.shtml
vern350 is offline   Reply With Quote
Old 04-15-2008, 06:11 PM   #4
Storm Chaser
Thanks for the link, it was real informative and a big help.
The only question it didn't answer is the one I am looking for- how do you bolt the axle, with it's perches designed for 3 inch springs, to a 2.5 inch spring? Do you just use the 3 inch hardware? Does the loss of .5 inch (or .25 on each side of the spring) hurt anything?
1988 R2500 Crew Cab
Future plans-
