04-14-2008, 04:10 AM | #1 |
shocks for bagged truck
im not sure what shocks i should run on the rear of my truck. im wondering what everyone else is running and their opinions
04-14-2008, 04:26 AM | #2 |
Re: shocks for bagged truck
are you bagged? lay frame? static? or stock?
04-14-2008, 04:39 AM | #3 |
layin frame
04-14-2008, 05:41 AM | #4 |
what you need to do is find a good spot for your shock mounts. measure the distance laying out and distance airred up all the way. take those numbers to your local parts store and tell them you want a pair of shocks that collapse to your lowest number and extend to your highes number. they will be able to find you something close to your spec.
good luck. |
04-14-2008, 06:24 AM | #5 |
what i was looking for was the brand of shocks others were using and how they liked them
04-14-2008, 06:26 AM | #6 |
ok kyb makes a good shock
04-14-2008, 06:32 AM | #7 |
I have stock rear and front shocks. The 65 stock rear shocks get a good bit of travel so I used them.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
04-14-2008, 06:33 AM | #8 |
mini truck mag has a tech this month on shock placement for what shocks you want to run.
it goes like this. desired wheel travel / Shock stroke = X ( shock postion, measured from the frame pivot ) X is a % of the total lengh of the a-arm or the rear lower bar here is the example they gave. Rear 10" (travel) / 6.5" (stroke) = 0.65 the rear bar they mounted it on was 30.75. 0.65 * 30.75 = 19.9 so they mounted it 20" from the frame pivot. then collapsed the shock and made the upper fame mount. the did the same on the front. Don't know if it will help but I was wondering it myself. by the time i got all this typed i see you just wanted a brand, maybe it will help someone else sorry.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared Last edited by GRIMSS; 04-14-2008 at 06:35 AM. Reason: slow typer |
04-15-2008, 11:40 PM | #9 |
I just installed Monroe Sensa-Track all the way around and like them. They were recommended here on the board by a few people.
04-16-2008, 12:56 AM | #10 |
those are one of the shocks ive been looking into.. im not sure what shock to get though because my bags are mounted pretty forward on my links so i can get alot of lift but ill maybe need a stiff shock so i can cruise as a low ride height. so im leaning towards some rancho 9000's so i can fine tune it
04-16-2008, 01:36 AM | #11 |
Seņor Member
This is a common topic in the forum.
