04-15-2008, 04:06 AM | #1 |
My project 55 begins
Here are a few pics. Its a 1955 BBW long box with a '59 283 v8 and 4spd
And now the tear down begins.... -Joel |
04-15-2008, 07:09 AM | #2 |
Re: My project 55 begins
She looked pretty good before you tore it down. Did she drive?
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe |
04-17-2008, 04:43 AM | #3 |
Yeah, I drove it home and around town a bit. It has the standard rust issues, rear cab corners and front cab corners. The plan is to have the body blasted to remove the rust and the minor filler work the previous owner did. I want to keep it as stock looking as possible on the outside but about 3 inches lower with a drop axle in the front and drop shackles in the rear. Disc brake kit up front and new master cylinder. It has a 12 bolt rear end already swapped in so I plan to leave that alone, though I may upgrade to a posi later. The 4spd truck transmission is useless for modern speeds so I'd like to find a ATM to replace it. The 283 is strong so I'm planning to just freshen it up a bit. Just your basic cruiser with some attitude.
-Joel |
05-08-2008, 07:19 AM | #4 |
So I have been able to play around with my truck last weekend and now I have removed EVERYTHING from the cab. Thanks to Zepreserve and my trusty air impact gun I was able to remove all of the cab mount bolts with out cutting and the cab is free from the frame. After I get back from my hillclimb race I will be taking the cab in to be blasted so I can tackle the rusty spots.
-Joel |
05-08-2008, 06:13 PM | #5 |
Looks like a few patch panels are in your future. Don't be discouraged. It will be beautiful when she's done.
06-04-2008, 01:23 PM | #6 | |
I like your style, I wouldn't mess with it much either. Looks like a great find.
1959 GMC project |
06-04-2008, 10:30 PM | #7 |
It looks like you have a great start...that will be a nice one.
1972 Cheyenne Super |
04-15-2008, 07:26 AM | #8 |
Welcome to the site Joel.
Looks like a real clean truck to start with. What are your plans for it? Kim |
04-15-2008, 03:35 PM | #9 |
Looks like a nice project. What's your plans?
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
05-08-2008, 09:41 PM | #10 |
Tot Roddin'
Wow... great looking '55!
Good luck with the build!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
05-09-2008, 09:07 PM | #11 |
Welcome to the 50's club and this forum! Other then the floors she looks to be not bad on the outside. Keep those pictures coming and ask any question you might have, there's a lot of knowledge here we are all willing to share, so ask away!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
05-09-2008, 10:03 PM | #12 | |
PITbut
Let me know when your heading to the blasters, i will send some more stuff with ya.... |
05-09-2008, 11:03 PM | #13 |
Quick question as you have both referenced blasting, but it would be nice to get anyone's opinion as well.
What is the typical going rate to blast the cab, inner/outer fenders, doors, bed and frame assuming that the disassembly is complete? Blast only? Would you have the same firm primer the components too? Just looking for general concensus. In Ft. Worth and have several options, just need to know what the typical rate is. Thanks to all. |
05-09-2008, 11:16 PM | #14 | |
PITbut
I had a front grill, 2 door hinges, one door, and 2 fenders blasted. With some sand and some plastic media and it was 225 bucks. They didnt offer the priming service. That would of been awesome. |
05-12-2008, 06:15 PM | #15 |
PROJECT 7DEUCE
Looks like shes in pretty good shape congrats...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-03-2008, 09:52 PM | #16 |
So I had some friends over this weekend and we picked up the cab and moved it to my trailer. One person on each corner made it easier than cake. I took it to the blasters in the morning and its due to be picked this weekend all fresh and clean and ready for patch panels. The frame is pretty naked now, but that just means that its all the better to clean up and work on the suspension. Without the body in the way it should go pretty quick.
-Joel |
06-04-2008, 12:49 PM | #17 |
your starting the funnest part short of the first drive. bare sheet metal repair... can't wait for more picts
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
06-08-2008, 02:42 PM | #18 |
Well I got my cab back from the blasters and the floors and cab corners were pretty much as expected. The left front cab mount that I was sure would need to be replaced is actually in a lot better shape and I can save it, but there is some extra work to be done around the top of windshield and some un-expected patch work that will be needed around the interior vents up under the dash. Over all I think it came out pretty clean for a 53 year old piece of steel! I also built a frame on casters so I can spin the cab 360 degrees and move it around in my garage by myself. It puts the cab at a nice height to work on as well.
-Joel |
06-09-2008, 11:02 PM | #19 |
I was just wondering what it cost you to blast the cab and what media did they use? sand? I have to get my cab blasted. I am just worried about warping the larger panels using sand. But i do like the way sand knocks the surface rust off.
06-09-2008, 11:22 PM | #20 | |
-Joel |
06-10-2008, 12:02 AM | #21 |
PITbut
Those prices vary eveywhere. I sent my 71 cab in the same time Joel sent his 55 in. His was 370. Mine was 350, but they did my core support, and a box full of other stuff. Really just depends on where you are. A good shop will use whatever media is best for the situation... NO soda. either sand or plastic.
06-14-2008, 02:15 PM | #22 |
Just wondering what your plans were for fixing the rust above the windshield? I have a 55 big window cab with the same rust at the top of windshield. Cab needs new steps,cab corners etc. My plan is to try and find a cab with good metal above windshield (about impossible to find) cut it out and replace the rusted metal on my cab. Has any one done this? Pics of repair?
06-14-2008, 02:25 PM | #23 | |
PITbut
I cant wait to see this thing... WOOOT.. excited... |
06-18-2008, 01:12 AM | #24 | |
-Joel |
10-21-2008, 08:22 PM | #25 |
I agree. Why no soda? I have just done my entire body and used a combination of sanding & soda and am very happy. Some say soda is easier to get out of the nooks and cranies later than sand and/or pellets. I think they are all good methods. The soda does have to be washed off but prior to that it adds some short-term or longer term protection depending on where you live to flash rusting. Also the soda may not be aggressive enough to get into some of the rusted areas but it surely exposes them.
Your cab condition looks very similar to mine except I have no rust around the windshield. I love that 327. What is the serial number? What was it originally from? I have a 327 block out of a 64-67 that was also used in the 66 vette and can't wait to get at it. Alas I am a long way from getting the engine done up. Trying to score goodies along the way. 56hotrodred Last edited by 56hotrodred; 10-21-2008 at 08:23 PM. |
