Old 04-16-2008, 02:50 AM   #1
torakki
Door Pin Bushing replace - easy quesion?
I just replaced the door pin bushings on my friends 2000 Blazer but not sure how to put th spring back in. The spring is on the top hinge and holds the door in two open positons. It has lots of tension and not easy compress to replace. Thanks for any input.
torakki is offline   Reply With Quote
Old 04-16-2008, 06:56 AM   #2
kaycee
kaycee's Avatar
Re: Door Pin Bushing replace - easy quesion?
I had to buy a tool for this ,I got it at carquest for under $15,I tried for hours with out it and finnally gave in and bought one.M ight see if autozone or someone has one to borrow some chain stoers do that.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 04-16-2008, 10:18 AM   #3
89 crew
On a topkick with the door closed it was an easy install. doubt it that will apply since your clip doesn't tilt, but you never know.
89 crew is offline   Reply With Quote
Old 04-16-2008, 09:10 PM   #4
torakki
Thanks for the responses. I had a feeling there was a "special" tool for this. Zip ties and a vice didn't seem to be working.
I will check the local auto parts stores. Thanks again.
Old 04-18-2008, 04:44 AM   #5
Tynee
I miss this truck.
Tynee's Avatar
zipties and a large pair of channel locks did the trick for me.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
