04-19-2008, 07:29 PM | #1 |
"brand new second-hand"
rearend swap .....anybody know
Anybody know what late model rearend can be swapped into a 69 coil spring truck-c-20? what available etc....
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
04-19-2008, 10:02 PM | #2 |
its all about the +6 inches
Re: rearend swap .....anybody know
if you can cut and weld, then most of them will work, if you can't cut and weld, then none of them will work.
04-20-2008, 08:37 AM | #3 |
Thanks for the info-I read somewhere that you can buy the spring mounting plates and the bracket for the panahrd bar-do you know a source?...thanks much again
04-20-2008, 02:51 PM | #4 |
WTB this ad
I want to say that Early Classic sells the mounting pads. The track bar.....You may have to go to a Super track bar that mounts to the trailing arm.
04-20-2008, 07:48 PM | #5 |
I think see ten is right.
I had forgotten all about that kit. I would imagine there is still welding involved, but that may be no big deal for you. |
