Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-20-2008, 03:42 AM   #1
Super73
Super73's Avatar
Rear widths..
Can anyone tell me the width of the 5 lug rears (I think late 70-73)? Thanks in advance.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-21-2008, 08:33 AM   #2
djracer
djracer's Avatar
Re: Rear widths..
I think they are wider than your stocker!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-21-2008, 11:11 AM   #3
wild one
Registered.........
wild one's Avatar
Re: Rear widths..
Stock width for a 1966 is 62" from drum to drum (point where the wheels mount).
The width for a 1971/1972 is 63.5" from drum to drum. The 1973 up rear ends are wider still.
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 04-21-2008, 04:16 PM   #4
djracer
djracer's Avatar
Re: Rear widths..
Great info thanks!
The later model disc brake explorer 31 spine 8.8's are 60.25 wide. Thats a pretty decent rear for the money.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-21-2008, 08:22 PM   #5
Super73
Super73's Avatar
Re: Rear widths..
So rear track width would narrow up 1" on each side with a 61.5" rear.. I have a later 71+ 5-lug rear.
Old 05-04-2008, 06:25 AM   #6
68c10owner
68c10owner's Avatar
Re: Rear widths..
I thought the 73 up were the same width as the late 70-72 style?
What rearend are you using now?
Anthony
68c10owner is offline   Reply With Quote
Old 05-04-2008, 08:03 PM   #7
Super73
Super73's Avatar
Re: Rear widths..
By my calculations (should have measured when the wheels were off) it's 63.5" wide. My tires messure out to almost exactly 12" I have a 12" draglite with a 7.5" BS. So total width tire edge to tire edge is 74.5" - 11" for the total BS and I get 63.5".
I am looking for a 9" right now that is 61.5" - 63.5" to replace the 12 bolt with. Any suggestions would be great.
Old 05-04-2008, 10:00 PM   #8
djracer
djracer's Avatar
Re: Rear widths..
the exporer rear would be just a little narrow at 60.25 with 31 spline axles. just put a spool in it and it sould be pretty good for cheap.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 05-05-2008, 04:20 AM   #9
Super73
Super73's Avatar
Re: Rear widths..
Any idea on the gear ratio? I'm just not to sure about going that narrow. Did you gt the one in your uncls truck. What wheels are on it. Can you snap some pics?
Old 05-05-2008, 06:24 AM   #10
djracer
djracer's Avatar
Re: Rear widths..
I haven't done his yet! I will do my little brothers first! I run a 4.30 with a 33 tire. I might do a 3.73 or 4.10with your shorter tire and spray it dead out of the hole!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
