04-25-2008, 08:58 AM | #1 |
speedometer cable install
could someone explain in detail how to install a 1972 speedometer cable. the transmission is a th350. after installing the new cable the speedometer wont work. what more do you do than screw it onto the bullet and back of guage?
04-25-2008, 01:17 PM | #2 |
Old member
Re: speedometer cable install
That's all you do. It did line up with the gear in trans. and the back of the speedo didn't it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-25-2008, 03:37 PM | #3 |
it had to line up or it would never screwed all the way down. the next question is did the speedo work before. if not the speedo or the gears for the speedo in the tranny tail shaft may be inop
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
04-25-2008, 05:20 PM | #4 |
I am getting ready to do this to mine.. Mine wasnt hooked up when I got it so I assume something is messed up.. I guess I will just pray my internals in the tranny are good.
Good Luck with yours I hope you get it working.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074 Toys: 2014 Dodge Ram 1967 SHORTBED |
04-26-2008, 04:53 AM | #5 |
the speedo gears in the tail shaft are easy to replace. remove drive line, disconnect speedo cable. remove 4 bolts from tail shaft housing and remove. there is a small clip that holds the drive gear for the speedo to the shaft. press down on the clip and slide it off. the cable gear is just a pull out from the cable housing.
04-25-2008, 07:02 PM | #6 |
Old member
Assumimg he got the right cable. Assumimg he can see the back of the speedo... which most can't. I would check it. Make sure it's tight and pulled all the way up.
