04-27-2008, 02:40 AM | #1 |
Life, Be In It.....
Radiator Suppor AC lines....Question
Can someone please measure the position of the hole in the radiator support. My support doesn't have the hole so I need to make one.
Sorry the picture is so small. I could not attach a larger one. See pic below. Thanks
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
04-27-2008, 02:58 AM | #2 |
member #16
Re: Radiator Suppor AC lines....Question
If you look closely , there is a dimple in the support where the hole is to be drilled. There are also dimples where the dryer clamp screws go.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 04-27-2008 at 03:14 AM. |
04-27-2008, 04:15 AM | #3 |
Life, Be In It.....
I think I have found which one your talking about and marked it in this picture. Is this the right hole? Any Idea what size the hole is?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 04-27-2008 at 04:24 AM. |
04-27-2008, 05:11 AM | #4 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
The hole you pointed out is for the front maker lights wire to pass through
Here is the right hole. It's about a 1-1.5" hole.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 04-27-2008 at 05:12 AM. |
04-27-2008, 06:01 AM | #5 |
Life, Be In It.....
Perfect. I guess I will have to remove the grill so I can drill a hole.
