04-27-2008, 11:01 PM | #1 |
flywheel
I am converting my truck from a 3 spd. manual to a th350, my ? is this do I need to change my flywheel? & if so what size, # of teeth do I use? truck has a crate 350.
04-27-2008, 11:09 PM | #2 |
Between Trucks...
Re: flywheel
You'll need a flexplate to replace your flywheel. Sorry don't know the size offhand, someone will chime in I'm sure...
Beat it to fit, Paint it to match... Last edited by Sinister; 04-27-2008 at 11:10 PM. |
04-27-2008, 11:26 PM | #3 |
Re: flywheel
will this work?http://www.partsamerica.com/ProductD...pe=267&PTSet=A
04-28-2008, 12:33 AM | #4 |
Between Trucks...
Re: flywheel
Not a flywheel. With an auto tranny you need a flexplate: http://store.summitracing.com/egnsea...=KeywordSearch
Beat it to fit, Paint it to match... |
04-28-2008, 01:02 AM | #5 |
Re: flywheel
count the number of teeth on your flywheel and that will be the number of teeth you'll need for your flexplate.
1997 GMC Sierra Ext 1965 Mustang |
04-28-2008, 05:48 AM | #6 |
Re: flywheel
ok I think I understand, also will I be able to reuse my old starter?
04-28-2008, 07:58 AM | #7 |
Re: flywheel
Yes, make sure you get the correct flexplate.
04-28-2008, 01:52 PM | #8 |
Re: flywheel
Yes, if you use the correct numbered teeth as stated above.
04-28-2008, 03:07 PM | #9 |
Re: flywheel
Since the stick has a bell housing where the starter bolts up with three bolts to the bell housing, a different starter will be needed. On the automatics the starter bolts to the block using two bolts. You will want the starter to match the flex plate.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
04-29-2008, 06:55 AM | #10 | |
Re: flywheel
04-29-2008, 08:10 AM | #11 |
Gone Fishing
Re: flywheel
168 tooth flywheel. depending on your power rating I might even order an SFI approved one
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
04-29-2008, 05:20 PM | #12 |
Between Trucks...
Re: flywheel
Flexplate, not a flywheel for an automatic...
04-29-2008, 07:54 PM | #13 |
Re: flywheel
yes this http://www.partsamerica.com/ProductD...pe=267&PTSet=A is listed as a flywheel but looks the same as a flexplate http://store.summitracing.com/partde...I&autoview=sku I think the aps jus has them listed the same, cause its listed for auto tranny.
04-29-2008, 02:19 PM | #14 |
Re: flywheel
Forgot about the starter being a stick. Yes an auto starter will be needed. Either way, just match the starter bendix head for either a 168 tooth one or the 153 tooth one.
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 04-29-2008 at 02:21 PM. |
