05-01-2008, 07:00 PM | #1 |
door assembly
what is the order of procedure for assembly of the door parts after it is hung properly.? Window reg first? door latch mechanisms first? Or what?
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: |
05-02-2008, 03:39 PM | #2 |
Re: door assembly
anyone????
05-03-2008, 04:28 AM | #3 |
Re: door assembly
ttt
05-03-2008, 10:49 AM | #4 |
Re: door assembly
This is the order of installation that I use:
-Door latch, including rods and actuator -Window regulator -Rear window track (left loose so it can be moved until everything is in place) -Window -Vent window assembly -Window seal -Window fuzzies Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
05-03-2008, 06:48 PM | #5 |
Re: door assembly
Thanks a million. That is exactly the info that i was looking for!!!!!!!!!!!!
