Old 05-02-2008, 02:41 AM   #1
VA72C10
VA72C10
VA72C10's Avatar
Throttle cable help
I have a 1970 and the PO installed a generic Auto zone throttle cable that attaches to the throttle assembly in the engine bay. The problem is it has failed twice (both times at night). It is a braided steel cable that fits into a fitting that is only held in by an allen screw you tighten against the cable. Is there an original cable that works better or something like a TV cable? Now that it's broken twice, the cable is too short and holds the gas pedal linkage so high the pedal pad won't hit it so i have to just push on the metal linkage and do so gingerly to make sure it doesn't come loose. Helps with the gas mileage but kills performance. I don't have any close ups of the set up i currently have but correct setups or recommendations would be appreciated (with pictures of course). Here's the engine at least. It has an edelbrock carb on there. I have to install a new bracket anyways to get the TV Cable hooked up for the T350 tranny. So bracket recommendations appreciated as well. Thanks in advance!
Old 05-02-2008, 03:25 AM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Throttle cable help
Any other setups out there that are out of chrome or billet that work well?
Old 05-02-2008, 01:46 PM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
Check out Jeg's and Summit for Lokar and other cable options.
Old 05-02-2008, 10:53 PM   #4
TonyJohnson
TonyJohnson's Avatar
Here's a pretty cool one I found...
http://cgi.ebay.com/ebaymotors/ws/eB...240235191&rd=1
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 05-02-2008, 11:26 PM   #5
lowriden58
lowriden58's Avatar
lokar works pretty good. ive only had one problem with mine and it was pulling thru the pedal, so i added a washer and problem solved!
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 05-03-2008, 01:59 AM   #6
VA72C10
VA72C10
VA72C10's Avatar
Thanks for the link. The problem with these are they mount in the firewall and don't hook up to the factory linkage. I'm looking for a short one to mount to the factory linkage.
Old 07-08-2008, 02:25 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
ANyone have a good option for the shorter style for a 1970? (not a firewall mount)
Old 07-12-2008, 07:21 PM   #8
71tahoe
71tahoe's Avatar
If you have the throttle lever that terminates in the engine compartment like from the factory in '70, then I recommend the original rod linkage and not a cable.
71tahoe is offline   Reply With Quote
Old 07-12-2008, 07:24 PM   #9
VA72C10
VA72C10
VA72C10's Avatar
But i have heard of issues using that with an aftermarket carb and intake. I have an edelbrock which should be very similar to the quadrajet in linkage, but if i switch to another carb, i don't want to go out to get another cable/rod. Any universal option other than Lokar's 24"?
Old 07-12-2008, 01:28 AM   #10
VA72C10
VA72C10
VA72C10's Avatar
ttt
