Old 05-02-2008, 01:06 PM   #1
basketcase
basketcase's Avatar
Radiator Overflow Tanks
What are you using for a radiator overflow tank? I want to run a closed system with coolant recovery so that the cross flow radiator will be full to the top all of the time. There are lots of tubular ones in the catalogs in various lengths and diameters but I'm not sure what capacity I would need for a non AC mildly built 355 that won't be doing any towing. They seem to come in all capicitys from 20 oz up to 56 oz.
It looks like I have room for a 3" diameter tank in between the radiator support and the grille with room to spare. Kind of hard to tell with everything apart.
Got pictures?
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 05-02-2008, 01:42 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Radiator Overflow Tanks
I just mounted a black JAZ bottle last week but I haven't got the tube for it yet. The black color is concealed well behind my 70' grille. I mounted it to my center grille support. The bottle has a valve on the bottom. I'll post pics when I get a chance.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-02-2008, 02:37 PM   #3
49m
49m's Avatar
I put a 70s corveete power steering overflow tank as mine and it works great and is small
My Rides
1969 Mustang gt coupe
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
2005 Ram 2500 Cummins
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=279831
49m is offline   Reply With Quote
Old 05-02-2008, 02:42 PM   #4
Stoney
Farm Truck
Stoney's Avatar
Does anyway have a picture of the original overflow tank.
Was there even ever one?
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 05-02-2008, 03:06 PM   #5
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I’m pretty sure they didn’t and the original doesn’t have the stem on fill neck to add a tank. (IIRC)
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 05-02-2008, 09:18 PM   #6
basketcase
basketcase's Avatar
s/t
Radiators have to have an overflow tube even if they don't have a tank and it just blows out on the ground. Otherwise something would have to blow apart when the engine overheated. My original does. You just have to change to a cap for a closed system so that the coolant can draw back in when the engine cools down.
A stock system will have the radiator overflow tube run into the bottom of the tank so that coolant will flow in and be drawn back out as needed. It will have a screw on cap on the top of the reservoir to check/add coolant and the pressure cap on the radiator will not be removed once the radiator is filled.
The problem I have with tanks like that Moroso is that you can't take the cap off to check your coolant level. They are designed to catch overflow so that it doesn't spill out on the race track. The tank should be about 40% full cold to make sure that the radiator is not drawing air back in when it cools and taking the radiator cap off to check coolant level doesn't tell you how much you have in the reservoir. Some of the reservoirs have a pressure cap which is fine if you have a radiator that doesn't use a pressure cap on the spout. I suppose one of these tanks is ok as long as you use a cap of lower pressure rating than the one on the radiator so as not to impead flow to the tank.
I'm trying to figure out how much coolant flows into the tank when the engine is at operating temp so I get one that is big enough with a little reserve. It seems like the plastic ones we used to buy as ad on kits in the 60s and 70s were about a quart. It's hard to tell looking at new cars with the crazy shaped tanks they use. I don't want to drain my car just to find out.
Tom
Old 05-02-2008, 10:13 PM   #7
lts70
1970 Daily Driver
lts70's Avatar
I think I heard some where that the dealerships had an over flow tank they put on our trucks originally. I thought it was on the inside of the core support by the horns. I have seen a lot of guys use a factory windshield wiper bottle on the opposite side fender mirroring the wiper fluid bottle for an original look. I got one cheap from NAPA and attached it between the battery tray and fender, works great no more loosing my antifreeze out the over flow tube. I also got a cap for a 73 and up Chevy truck to have the correct seals for the overflow.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 05-02-2008, 10:44 PM   #8
Sinister
Between Trucks...
Sinister's Avatar
Here's mine. It looks factory, might have been a dealer option though.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-24-2008, 12:42 PM   #9
WIDESIDE72
WIDESIDE72's Avatar
s/t
Here is a picture of the SPID label from one of my 72's. No tank under the hood, though. i am still waiting for someone to furnish a pic of this elusive creature. Maybe it is hanging n Bigfoot's garage?
WIDESIDE72 is offline   Reply With Quote
Old 02-21-2011, 09:13 PM   #10
Avalance1
I will snap a few and post them asap...do have more pics of your truck I think I own the twin to it?
Avalance1 is offline   Reply With Quote
Old 05-02-2008, 07:16 PM   #11
muscletrucks
muscletrucks's Avatar
Here is what I used on my last project from Summit Racing $ 28.95: http://store.summitracing.com/partde...5&autoview=sku
Summit has their our label for $ 13.95: http://store.summitracing.com/partde...5&autoview=sku
1972 GMC Sierra Grande 3/4 Ton 4x4
1970 Mercury Cougar XR7
1943 Farmall M
muscletrucks is offline   Reply With Quote
Old 05-03-2008, 04:32 AM   #12
71 super
71 super's Avatar
Here is a picture of the one on my 71. It is a dealer only option and there were several different types. This one was a NOS item I got off of E-bay. It is identical to the few that I have seen on untouched trucks. The bracket mounts on the core support above the horn(s) and the hose comes from the overflow vent to the bottom of the tank. I paintd the cap so that it would match the overflow, but this is real deal -or at least one version of it.
71 super is offline   Reply With Quote
Old 12-24-2008, 12:43 PM   #13
WIDESIDE72
WIDESIDE72's Avatar
Where is the picture?
Old 05-03-2008, 04:48 AM   #14
68 short step
heres the ones i use, its a billet specilities peice.
68 short step is offline   Reply With Quote
Old 05-18-2008, 01:11 PM   #15
tommypic
tommypic's Avatar
lets see some under hood pics . what fan setup are you using ? not meaning to high jack the thread
My ZipCode = 29673
2008 Silverado Z71 LTZ Wrecked New Ride SOLD
71-72 Custom A/C Parts Truck < selling parts
67 Chevy ShortStep SOLD
67 GMC SWB Step <-- For Sell
67 Chevy SWB Step <-- working on
2000 Road King <-- SOLD
97 F150 my ride for now
2006 Escape wifes ride
HELP SUPPORT THE BOARD http://67-72chevytrucks.com/vboard/payments.php
Great How To Thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Vendor Sites http://67-72chevytrucks.com/links/browselinks.php?c=2
tommypic is offline   Reply With Quote
Old 05-18-2008, 01:51 PM   #16
basketcase
basketcase's Avatar
I see a few mounted on the driver's side behind the core support. There is a lot of room there and it won't show through the grille. I'm going to have to think about that.
Tom
Old 05-20-2008, 08:49 PM   #17
chevy72blu
chevy72blu's Avatar
Sorry for the quick hijack, buttttt
Can I see a few more pics of your fan install? I have the same setup (still in the box) and It looks like you made your own simple brackets. Thanks!
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 05-21-2008, 09:01 PM   #18
basketcase
basketcase's Avatar
I put the old grille on last night to check for room to mount the tank. Since mine is 3" diameter it's a tight fit in front of the core support unless I mount it on the center support like in post 21. The downside of that is all of the bugs and stuff that comes through the grill will splatter in it.
It can't go on the inside on the right side because of the battery tray and I'd have to make special brackets to mount it between the battery and fender. It's too pretty to hide like that anyway. I think i'll put it on the core support on the drivers side above the weld nut for the horn. It's just 10" long so it should be fine there and I can see and admire it. I may even run a hard line to it if I can find some stainless tubing. I guess aluminum would be ok too.
Tom
Old 12-23-2008, 10:15 PM   #19
lghtng2
I'm gonna do mine just like that with the overflow tank from billet specialties
lghtng2 is offline   Reply With Quote
Old 12-23-2008, 11:58 PM   #20
big_al_71
big_al_71's Avatar
here is my set up.....hose ranned under the rad support....it looks black but it is billet it is the reflection of the inner fender....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-03-2013, 01:13 AM   #21
JonCheun
What size 90 fittings are those? Thats the braided hose right?
I'm about to replace my radiator and overflow tank.
I really like this look
JonCheun is offline   Reply With Quote
Old 05-03-2008, 04:50 AM   #22
muscletrucks
For sale as we speak.
http://67-72chevytrucks.com/vboard/s...d.php?t=290212
1943 Farmall M
Old 05-09-2008, 12:27 PM   #23
basketcase
basketcase's Avatar
I just got mine in from Speedeway Motors. Polished stainless with a billit cap. I ended up buying the 3" diameter by 10" long. I'll post a picture whn I get it mounted.
Old 05-09-2008, 02:57 PM   #24
tommypic
tommypic's Avatar
one for sale here
http://www.67-72chevytrucks.com/vboa...d.php?t=286036
My ZipCode = 29673
Old 05-18-2008, 08:03 PM   #25
chevy72blu
chevy72blu's Avatar
I have one of those dealer installed tanks, located on the passenger side. I removed it to place my MSD box on that fender and im using one of the Summit brand cans on the inner fender well between the inside of the fender and the battery box. I'll have to remove the battery box to drill the holes, but it should fit well and be pretty hidden
RIP EastSideLowLife
