One day...
Tubing benders????
Just wanted to see if anyone knows where to buy a tubing bender, like the kind for frame tube work and stuff like that... Any ideas??
![]() Thanks, Scott |
Re: Tubing benders????
http://www.jd2.com/ there is one that is not to expensive you can also google tubing bender and 100s will come up
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
![]() Join Date: Aug 2006
I bought a JMR tubing bender. I got just there manual bender with an 1 1/2" die with a 5" radius and i love it. I wouldn't mind upgrading to an hydraulic but wanted to make sure i like and use it enough. I absolutely love it. Here is where i bought mine http://www.tricktools.com/ . You really should buy this mount for you protractor though when you get a tubing bender. It is a necessity for doing multiple bends. Also you should get some lube for the dies so you don't wear them out. It helps preserves them and they are not cheap. Here is a pic on what i did with mine
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
One day...
Man that looks good! Thanks for the info guys!
