60-66 VS 67-72 frame, the same?
I'd like to know if the swb frame on a 60-66 chevy are direct fit on a 67-72 body. Is it the same frame? Thank's
'71 Custom/10 Deluxe LWB '71 Custom/30 Deluxe Dually |
![]() Join Date: Aug 2005
Re: 60-66 VS 67-72 frame, the same?
The '60-'62 chassis is quite different from the '63-'66.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
Ok but the 63-66 are the same?
Born Psycho
![]() Join Date: Feb 2001
60-62 used torsion bars in front, cab mounts are different, front frame horns are different where the bumper bolts on. we did a lot of comparison when we converted a 63 2wd that belongs to my nephew over to 4wd. we were going to put it on a 69 swb 4x4 frame but i ended up finding him a 65 swb 4x4 frame and we put later running gear under it instead. disc brake dana 44 front, power steering off of a 73, SM465/205 combo from the same 73, 12 bolt rear from the 69 and brake booster/master cylinder from an 81. we built the chassis and had everything ready to go so he drove up in his 2wd on a friday after he got off work and drove home on sunday in a 4x4. it was a lot of work in a short amount of time but sure made a sweet little truck out of it.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
thank's jerry but i'm talking about a 2wd, front and rear suspension like to be the same on a 63-66 and 67-72.
i guess that kind of answered the question but not really. i was under the impression that except for cross member locations they were basically the same frame. so i guess what i'm getting at is which would be better to do, convert a 64 swb to fit under a 68 truck or chop the 68 lwb to use as a swb
Born Psycho
personally, i'd shorten the 68 frame since the cab mounts and frame horns are correct. the frame rails are pretty much the same except the bumper mount area.
