05-06-2008, 05:16 PM | #1 |
Pitman Arm Bending
Anybody ever heat up and bend a pitman arm before?
Did you quench it? Did it break with use? Here's my deal: I got the crossover steering almost done on my Blazer, except for the pitman arm. I read on the net that a 78-79 Ford f150 or Bronco pitman will work on a GM 2wd box. It fits, but it hits the frame when the DLE/TRE is installed. And it is angled the wrong direction about 5 degrees. I want to heat it ,and bend it down a little ,and angle it the other way to make the TRE at 90 degrees at ride height. It seems to be forged steel. I milled 2 flats down on the big end of the arm so my puller would fit it, and my shell mill was throwing sparks. What do you guys think.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
05-06-2008, 08:50 PM | #2 |
Re: Pitman Arm Bending
I wouldn't do it. Annealing it would make it softer and of course the metals never the same.
I used a Wagoneer arm on mine. Worked well and I reemed out the end for 1 ton TRE's. |
05-07-2008, 01:03 PM | #3 | |
MidlifeCrisisUnderWay
X2 |
05-07-2008, 02:20 PM | #4 |
I found this on Jalopy Journal:
Do NOT cut the Pitman arm, unless you REALLY know what you are doing. Heat,bend,allow to cool in still air. Common question: http://www.jalopyjournal.com/forum/search.php And this too: I have heated and bent a few. I think all the factory parts are forged steel. It will take it if you let it cool down slowly as allready said here. If you shorten the arm you will change your steering ratio. Never ever cut one in two and weld back togather. I have seen that type of work fail. my .02 Steve One more: I have bent one and it worked just fine. But when you heat it wait till it is red hot and bend slowly, with only mild pressure. Let it cool by itself, then when the one bend has cooled, then do the same for the other bend and you will have what you need and it will be plenty strong. I agree, do not cut and weld, besides looking horrible. And: Bucket of sand slows the cooling. It sounds like these guys do it all the time. But they dont run 33" tires on the front and race through the woods. I think i will try and find a Wagoneer arm and see if that fits my set-up better.
05-07-2008, 11:10 PM | #5 |
I have bent one for a offroad truck never failed on me. but I would never ever do this for something I'd drive on the street. If you cool metal really slow it has beter chance of bending before it would snap off.
05-08-2008, 02:21 AM | #6 |
.....I am working on it.....
How about this, saw this in a different forum and thought...........hhmmm, good or not???
05-08-2008, 02:27 AM | #7 |
Looks like the stock arm had been cut, then a new mount welded to it.
05-08-2008, 02:44 AM | #8 |
(A) for trying but a little thin on the metal.For shure that is somthing I wouldn't do myself
05-08-2008, 03:00 AM | #9 |
I agree and the material used, but using this pic for reference, would this be safe to cut and weld onto the stock arm?
05-08-2008, 03:10 AM | #10 |
To me it looks like they put bracing around the stock arm you can see part of it inside.
05-08-2008, 03:25 AM | #11 |
Even if you welded it and got full penetration. it would still need some form of heat treating.Being a welder myself I'd still go and get one from a offroad shop.$100.00 to 150.00 bucks for peace of mind is worth it for me.
05-08-2008, 02:02 PM | #12 | |
I dont want to spend $100-150 for a pitman arm. If the OEM ones are good enough for the factory. They are good enough for me. Its just finding one that works in the junkyard. Im going this saturday to search for a Wagoneer/ Cherokee /J-10/20 .
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania Last edited by OLDCHEV4X4; 05-08-2008 at 02:06 PM. |
05-08-2008, 03:19 PM | #13 |
wfoconcepts.com
Pitman arm new should be less than 80.00 I even went and looked: http://wfoconcepts.com/Steering/Stee...s/HvyDty4.html 75.00 Last edited by FormerMember; 05-08-2008 at 03:19 PM. |
05-09-2008, 01:44 AM | #14 |
Personally I wouldn't worry about bending one. If it is heated enough to bend easily and cooled slowly, it should be fine. The worst you can do is "soften" it slightly. This may make it more susceptible to bending, but not breaking. Cross-over steering will take a lot of the load away anyway, it is far easier on parts.
It shouldn't have to be said, but I haven't seen it so far in this thread so.... Be sure you remove the arm from the steering box before heating it. The heat required to make this bend will definitely hurt the seals in the box. |
05-13-2008, 02:15 PM | #15 |
I found a Grand Wagoneer finally after 3 junkyards. $20 and some dirt in my eyes. ( forgot my saftey glasses). I tapered the hole just enough to get the cotterpin in so that the stud dosent stick out too much.... And it hits the frame too.
Not by much, but it hits. So i heated it up and bent it a little, let it cool in still air, and hope for the best. I'm going to tweek the f150 arm too and put that one on because its beefier than the other one. I will carry the Wagoneer arm as a spare. Crossover is done and works good.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania Last edited by OLDCHEV4X4; 05-13-2008 at 02:16 PM. |
05-14-2008, 03:34 AM | #16 |
Cool!! Now show us some pics of the project.....
05-15-2008, 07:42 PM | #17 |
here is one we made....
The pitman arm was made from a stock arm. The splined part that engages the steering box was cut off and machined round. The plate pieces were cut on our cnc plasma table. On the end of the arm where the splines needed to be I left a round hole on the arm body. The splined piece was dropped in the hole. The arm was made for use with a rod end. It was built to run the rod end in double shear. As for welding the arm it was tig welded. I will see if I can dig up some more pics from the build process and post up. Might help explain a couple things for those wanting to make one. As for heating and bending a pitman arm I would not recommend it. I have seen many of them fail over the years. I am not saying I know all, but I will say it sucks getting it off the trail with no pitman arm. To me it is not worth the potential breakage. As for the pitman arm we build it is on a purpose built comp rock crawler. It is not driven on the road. The vehicle is only used for comp and trail use. If you have any questions let me know. -Dan Last edited by dan@bluetorch; 05-15-2008 at 07:45 PM. |
05-15-2008, 08:20 PM | #18 |
Welcome aboard Dan. Looks like you joined the group today.
I am only running 33 10.50 tires. And my race truck never sees to road. And i am going to carry a spare. If it fails i'll change it, and then take the easy way back to the trailer. And then i too will preach about why you shouldn't bend a pitman arm. But for now, I'm gonna give it a try.
05-15-2008, 11:17 PM | #19 | |
05-15-2008, 11:47 PM | #20 | |
Very nice!! How much shipped to So Ca? |
05-16-2008, 01:07 AM | #21 |
LOL... we built one for our Red Bull comp car. They changed the rules shortly after building the car. They can is now running full hydro. The pitman arm is actually in So Cal.
It is very easy to make one. Let me know if you need some pointers. -Dan |
05-16-2008, 01:22 AM | #22 |
That is provided you can weld like Dan... and understand metallurgy like he does.
05-16-2008, 06:00 PM | #23 | |
I could easily make my own, but I figured yours is done, eliminating my labor time No problem. Thanks anyway. |
