Chevys Kick A$$
Need help with front driveshaft for my '91 Blazer
All right I got another truck I know I need pics I will get them up later this week. The one major problem is I need a front driveshaft. I was told '73-'87 Chevy and gmc truck and '73-'91 Suburban as well as '73 and up full size blazer driveshafts will work is this true? I know I need to measure to be sure I just want to know all what ones would work. Thanx for any help and input!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
Re: Need help with front driveshaft for my '91 Blazer
Not entirely. I think you will have better luck if you can find one from an 80ish and newer Blazer/Suburban/Truck.
The front driveshafts are different lenghts based on what type of tranny & transfer case you have. Also, how the front driveshaft bolts up to the output of the t-case can be different. I'm not sure when it changed, but the older ones are different. My friend is in a similar situation with his 76 Blazer. Someone stole both of the driveshafts from it and I found replacements off a shortbed truck that had an SM-465/NP-203. The Blazer is SM-465 with an NP-205. I had the rear driveshaft shortened and was hoping the front would bolt up, turns out the front will need to be shortened too. Hope this helps.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 Last edited by rcbildr; 05-09-2008 at 06:07 PM. |
huh ???
Does the 91 have any lift? Is it an auto or stick? The t-case should be an NP241, pretty much the same as a NP208 but has an electronic speedo. You should be able to use a front shaft from any 4x4 pick up from 81-87 and any blazer or burb from 81-91...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Chevys Kick A$$
Yea thanks for the advice. I ended up getting one off a early 80's Blazer and it bolted right up so thats good.
