Old 05-10-2008, 02:55 AM   #1
68gmsee
Active Member
68gmsee's Avatar
My 68 1/2 ton GMC has 8 leafs. Is this right?
About 15 yrs ago a friend of mine removed some springs from my 68 half ton short bed GMC to lower it for me. He removed 2 springs from the bottom on each side and left 6. Now I'm trying to put it back the way it used to be and not sure if I have it right.
Is 8 springs on each side correct? The springs are the 2 1/4" width.
Second, do the springs go shortest on bottom longest on top? On my truck the shortest one (about 12" long is on the very top). Not sure if he did that.
And last, the distance from the center of the spring to the ends is not equal. Does the longer half go to the rear???
Any help appreciated...
Disregard oil on the wheel. I replaced a leaking brake cylinder.
68gmsee is offline   Reply With Quote
Old 05-10-2008, 05:46 AM   #2
lilred67
lilred67's Avatar
Re: My 68 1/2 ton GMC has 8 leafs. Is this right?
it appears that someone has added some leaves to that spring pack. a couple of the thicker bottom springs.i have a '72 gmc 1/2 ton frame and it only has 5 springs. my '68 gmc 3/4 ton beater has 7 or 8 springs. the springs should be stacked shortest on bottom to the longest on top.hope this helps.
lilred67 is offline   Reply With Quote
Old 05-10-2008, 04:26 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Thanx, lilred67... I guess that the short piece on top should go on the very bottom. I'm think my buddy placed it on top to assist in the lowering.
I may just look around for some lighter springs or leave the extra ones off since I won't be using it for heavy hauling...
Old 09-08-2008, 10:32 AM   #4
68_GMC
68_GMC's Avatar
My truck came stock with 9 leafs. I had a new set made because the 2 main leafs were broke. I was told only 10% of the 68 GMCs made are leaf springs.
68_GMC is offline   Reply With Quote
Old 09-08-2008, 10:35 AM   #5
68_GMC
68_GMC's Avatar
I just noticed the U bolts are missing. Do you have them on now?
Old 09-08-2008, 01:38 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Yeah. I was experimenting with removing some of the springs to lower it a couple of inches when I took the picture...
Old 09-08-2008, 06:36 PM   #7
too much stuff
Roadtrip!
too much stuff's Avatar
I don't think i have ever seen a 68 gmc without leaf springs. I think one of mine has 7 on one side, and 8 on the other. Also a 1/2 ton. I would have to look at my other to see...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 09-08-2008, 08:06 PM   #8
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
my bare '68 GMC 1/2 ton chassis has 8 leafs...but they're coming off to make room for a 4 link.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-08-2008, 04:04 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
who told you that 10% of the GMC trucks had leafs?
GM didn't keep very good records back then, but considering GMC had a lot of trucks sold as work trucks, and the fact that in 68, the leafs were base equipment on ALL there truck models.... your source is probably mistaken.
Add that to the fact that all the GMC records were lost... and I say someone was pullin numbers outta his dana.
Old 09-08-2008, 04:38 PM   #10
Senator350
Senator350's Avatar
WOMP WOMP WOOOOMMMMMMP
RN U OVR
Senator350 is offline   Reply With Quote
Old 09-08-2008, 04:51 PM   #11
67mater
67mater's Avatar
http://67-72chevytrucks.com/vboard/c...ct=2277&cat=12
check my for sale ad; 7 mains and 3 overlaods!!!!, shortest to longest; completely factory.
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
