Old 05-11-2008, 08:21 AM   #1
lyrikz
PITbut
lyrikz's Avatar
How do you tell when a rebuild is needed.
How do you tell when a transmission needs to be rebuilt?? I have a TH400 that im puttin in my truck. The vehicle i took it out of the tranny felt fine. I do need a different torque converter on it, (new cam on new motor) but what do i check inside the trans>???
i do have a book on its way on how to rebuild a TH400, but i was hoping i could get some advice.. Impatient on the book. ahah
lyrikz is offline   Reply With Quote
Old 05-11-2008, 08:42 AM   #2
89 crew
Re: How do you tell when a rebuild is needed.
It depends on what you want from the trans. If you want perfection, rebuild it. If a minor leak is acceptable run it till there is a problem then rebuild.
89 crew is offline   Reply With Quote
Old 05-11-2008, 08:58 AM   #3
HoupPhotography
Since you have a new motor, I would rebuild it, IMO, if the thanny leaks that is a problem. Take a little extra time to make sure you don't have any leaks, less headache, more drive time & less down time. If I'm going to do something, I try to do it once and be done.... but it doesn't always work that way....
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 05-11-2008, 03:36 PM   #4
Gray Ghost
Gray Ghost's Avatar
Just had mine rebuilt....first sign is when the seals go and it's hard to engage when cold. Other signs are slippage in one gear or another or slow shifts.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 05-11-2008, 05:34 PM   #5
lyrikz
PITbut
lyrikz's Avatar
I dont have any of those signs.... Im leaning towards the rebuild... Since im putting in a new torque converter and shift kit, i figured rebuilding it wouldnt hurt.
Old 05-11-2008, 06:26 PM   #6
oldspowered
resto body guy
i think a trans rebuild is cheap insurance! that way you don't have to pull it back out 3 months down the road!
http://i3.photobucket.com/albums/y86...DSC_0004-2.jpg
trucks are ment to haul!
oldspowered is offline   Reply With Quote
Old 05-11-2008, 08:52 PM   #7
HoupPhotography
Just one more reason to rebuild it.....
Old 05-12-2008, 08:17 AM   #8
sickchevy68cst
Rice Killing 101
rebuild it cuz so far ive had to pull my friends 727 torqueflight out 5 times now we're pros at it so get it out of the way so much easier than pullin it out every weekend
distrubin the peace since i got the thing and broke the origianl radio on 95.5 classic rock
Ride:
1968 c20 lwb 327(orig motor)/np435/eaton 4.10 w/posi
puttin in a 496 rebuilding trans need to rebuild diff :|
need to start takin pics and start a project thread
sickchevy68cst is offline   Reply With Quote
