![]() Join Date: Apr 2008
Motor mount question
I know from word here that a 73-87 front suspension or whole crossmember will bolt up in a 67-72.My question is this,will the V8 motor mount plates from a 73-87 bolt up in my 67.Im going from a 6cyl to a V8 and am getting a V8 from an 87 C10 if I could also use the motor plates that would be great.
![]() Join Date: Apr 2007
Re: Motor mount question
I dont know how those 87 mounts will work but your 6 cylinder mounts should work. is the87 TBI what are you gonna do about that?
The 87 is TBI but the throttle body is missing along with the dist.Havent decided if Im going carb or fuel injection yet but if I do it will be a port style injection.So the 6cyl mounts are the same?
The brackets on the frame are the same the mounts Im 99% sure are the same there is like an extention bracket between the mount and the 6 cyl block. Id use a carb on that its a ton of stuff to put a tbi in something that didnt have one. you can get an edelbrock intake for a tbi motor or you can modify a regular intake by sloting out the holes in the heat riser ports so the bolts that go in straight will go in.If that makes sence.
