Old 05-12-2008, 07:20 PM   #1
bfr57
bfr57's Avatar
Speedometer Cable Lube?
My 71's speedometer really chirps and makes alot of noise on cold mornings. The needle will also jump around as much as 10 mph gaps. Once everything warms up, everything goes back to normal. I'm afraid it's going to break one of these mornings. I've taken the cable off the back of instrument panel and tried different types of lubes from WD-40 to oil, but nothing works. Anybody know of something that'll work?
bfr57 is offline   Reply With Quote
Old 05-12-2008, 07:33 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Speedometer Cable Lube?
I would pull the cable out, clean it with brak clean, then also clean the cable housing with brake clean... just unplug both ends and hose it out with the stuff, then after an hr or so to dry, I would get some liquid graphite spraty, and spray a bunch in there till it starts pouring out the other end. then slide the cable in and call it good. You'll also want to make sure the cable isn't too short (engine and tranny swaps will cause this if not the same set up as original) and make the bends easy and not tight.
Old 05-12-2008, 07:51 PM   #3
71 super
71 super's Avatar
Yuo can also get powered graphite lube, mix w/ rubbing alcohol and spray it in using squirt bottle if you can't find graphite in solution already. The alcohl will evaporate and leave the suspended graphite in place - instant cable lube, also works for sticky locks etc that are hard to get at.
71 super is offline   Reply With Quote
Old 05-12-2008, 08:03 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I'll agree graphite is probably the best -- but I used white lithium grease (maybe 25 years ago?) and have not had a problem since.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 05-12-2008, 08:26 PM   #5
Longhorn Man
white lithium grease can be kinda thick if you are in a colder reigon
Old 05-13-2008, 12:44 AM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I hadn't really considered that. Coldest I've seen here is zero, and it doesn't usually get below about 15 very often...
- Mike -
RIP El Jay
Old 05-13-2008, 12:40 AM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Lock Eaze,It's a mixture of graphite and something liquid for a carrier.It is great for locks and works well for speedo cables also.I agree with LHM clean everything up good first.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-13-2008, 03:36 AM   #8
jimfulco
I've pulled a couple out and lubed them with wheel bearing grease with no further problems, but it rarely gets below ~10*F here, either.
I'd be hesitant to use rubbing alcohol because it's usually only 70% alcohol, and when that evaporates, the leftover 30% becomes 100% water, which might cause corrosion.
jimfulco is offline   Reply With Quote
Old 05-13-2008, 03:49 AM   #9
WorkinLonghorn
WorkinLonghorn's Avatar
1969 Service manual says 90 wt gear lube for the tach cable,so I think that would be about right for the speedo too.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 05-13-2008, 05:53 AM   #10
bfr57
bfr57's Avatar
So, you can pull the guts out of the exterior sheath and leave that in place? The gear oil idea sounds good, but you know how that stuff smells!
Old 05-13-2008, 06:25 AM   #11
WorkinLonghorn
I use it for cologne. No seriously,yeah,the cable pulls out of the sheath which stays in place. Some of the posts above about cleaning etc. might be good advice.I'd try just oil first though.Always worked for me on trucks cars and bikes.
