Old 05-16-2008, 03:25 AM   #1
skokie
skokie's Avatar
Rear brakes locking up before fronts
I had a break job done on the 68 1/2 ton. Its power drum/drum. New shoes, master cylinder, rotors, everything. When I slam on the brakes the rear locks up before the fronts. Do I just need to adjust the fronts a bit?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 05-16-2008, 03:35 AM   #2
Pont406
Re: Rear brakes locking up before fronts
I can't help you much, but my 69 c10 does the same. I tryed everything and it still does it.
Pont406 is offline   Reply With Quote
Old 05-16-2008, 03:40 AM   #3
tcb-1
Nothing to see here.....
tcb-1's Avatar
hummmm, I have a couple of thoughts.
the front and rear brakes may need a bit of adjustment.
or
you may need an adjustable proportioning valve aft of the existing proportioning valve. but if you haven't touched the factory master cylinder and prop valve, something changed.
or
you can also try rebleeding.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 05-16-2008, 04:37 AM   #4
powell72
powell72's Avatar
The rears will always lock up before the fronts. When you stand on the brakes it takes the weight off an already light rearend as the front dives. Assuming whoever did your brake job did it correctly, you shouldn't need to adjust yet (you sound like it was recent). How does the pedal feel? Is it high and firm? Jack up the truck and see if there is some drag on the wheels when you spin them if you are concerned.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 05-16-2008, 07:38 AM   #5
skokie
skokie's Avatar
Will give this a try and see.
68 build thread
Old 05-16-2008, 04:41 AM   #6
Sammy
After putting everything in my brakes new including drums, I noticed one of my drums was getting super warm. Come to find out one of my drums (new) was out of round. Never know what U get now days. Jack her up & check it out.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-16-2008, 08:17 AM   #7
Rollie396
someday it will be done!
Rollie396's Avatar
did you back up and hit the brakes a few times to adjust the rears?
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 05-16-2008, 08:56 AM   #8
cobb_ben
cobb_ben's Avatar
That should not be a problem. It should actually be safer, because if the fronts lock up then you can loose your ablity to steer! That is not good!
'69 Chevy C10
400sb-350 crank 400 destroker!!! 377
2.02 dart pro1 alum.heads
msd, holley db
hooker pro-comps-3in exh.
3 spd. saginaw-3.73posi
Flat Bed...want Reg bed...trades?
cobb_ben is offline   Reply With Quote
Old 05-16-2008, 01:45 PM   #9
NGN
NGN's Avatar
just a short time after buying my 67my rear driver side was locking , i was told the brakes had low miles but where done awhile back . put the truck on stands to check out the brake system. fronts drums frist , all the pads are new no lecky brake-cyl , clean . what we found in the rear drums was that the new pads were put on wrong , the two longer shoes on the rear driver side with a wet brake-cyl and the two shorter on the pass side . replaced the brake cyl's and pads bleeded the system and that fix it . be safe check it all out good luck
NGN is offline   Reply With Quote
Old 05-16-2008, 02:00 PM   #10
70GMCer
70GMCer's Avatar
There is not prop valve for drum/drum brakes. It has a distribution block. Brakes systems are designed to have the fronts lock up before the rears. That keeps the rear of the vehicle from swinging around and going out of control. Read your manual on adjustments & how the brakes react to sudden stops. It sounds like you have the rear adjustment tighter than the fronts.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-17-2008, 04:06 AM   #11
72hotrod
72hotrod's Avatar
You always want the front brakes to lock up before the rear to keep from losing control. The closer together the better, but fronts first.
On a drum-drum system, the size of the brake components (front vs rear) provide the proportioning effect. If your rear wheel cylinders or brake drums and shoes were to be upsized without changing the fronts, your brake bias would increase toward the rear.
DPI Racing supplies a dampening valve for the rear called the Stewart Lock-Resistant Brake System (LBS) that is used by NASCAR teams to help prevent lock-up at the rear during hard braking. It just goes in the line at the rear hose on the frame. I don't know how good it works, but I am looking into it, as trucks need a lot of help in this department. They cost about $90.
72hotrod is offline   Reply With Quote
Old 05-17-2008, 06:09 PM   #12
bb1979
bb1979's Avatar
I prefer the backs locking up first, I find it much easier to control than having the front slide out on you
1979 C20 pickup 454 big block turbo 400, 4.56 gears
bb1979 is offline   Reply With Quote
Old 05-17-2008, 08:49 PM   #13
OrangeCrush1970
OrangeCrush1970's Avatar
You never want to lose your rear end unless you know how to pull yourself out of it. Try backing up and pumping the brakes whlile bringing it to a complete stop (do this several times). We have self adjusting drums - this should help you out as I had the same situation on my last brake job.
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
Old 05-22-2008, 06:33 AM   #14
skokie
skokie's Avatar
I tried that and it didnt do much. Maybe I didnt do it long enough times. About 5-6 times or more than that?
68 build thread
Old 05-22-2008, 06:42 AM   #15
Arad68
Trucks N Tranzams
Arad68's Avatar
I advise switching to front disc if you can, but an adjustable brake valve will make a huge difference.
Our trucks, or any pickup truck for that matter, are inherently light in the back
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 05-22-2008, 03:46 PM   #16
OrangeCrush1970
Try backing up and slamming on the brakes a few times (watch your head and the back glass!)…it may take 5 or 6 times depending. Also, seeing as they are new brakes, they may just need a wear in period, that’s just a thought though-
If this doesn’t work you may just need to manually adjust the rear drums. It's a little easier to do on the front than the rear, but essentially you want to make sure that your rear brakes aren’t set too tight. Block your front tires, jack the rear up and put it in Neutral, etc. If you get your rear wheel off and your drum won’t pull off freely, then it is probably just set too tight. ….if you spin the rear hub and you can hear the brakes rubbing then they are probably set too tight. Adjust until there is as little friction as possible.
Rottenwood Garage
2 Tons of Fun
