Old 05-16-2008, 03:17 PM   #1
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Question about Proportional Valves
I've swap to disk brakes in the front and I'm wondering if anyone knows if other/later years proportional Valves will work. My disk setup is from a 71/72 truck. I was thinking of going to the boneyard and seeing if there's any early model vans, 73-87 trucks or even the early model Silverado's (90's). Or are we specific to the 71'/72' parts. Thanks.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 05-16-2008, 04:01 PM   #2
chris71
chris71's Avatar
Re: Question about Proportional Valves
not a brake expert, but i think that the gm prop valve is pretty universal given the fact that they are all off of front disc rear drum vehichles, stay away from 4 wheel drum (dont have a prop valve)and 4 wheel disc vehichles (different), i personally would feel comfortable using a 73-87 prop valve, and would probably stay away from the newer prop valves, make sure to stay away from anything with abs. i just picked up a new universal GM prop valve for $60 at a swap meet from one of the bigger brake companies
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 05-16-2008, 04:03 PM   #3
Sammy
Different years may work a long as U keep front disk P valve only donor. Another thing to consider is the hard line hookup from master & front/ rear supply lines. Remember your talking brakes keep safety in mind.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
