Who All Makes 6 LUG Wheels in ...
18" and 20" That will Fit a 1970 GMC Trucks.? Any Ideas or Suggestions Appreciated. Looks Like centerline Offers 6 LUG Wheels,but I cant tell from there web site if they would work.
Re: Who All Makes 6 LUG Wheels in ...
That's kind of a loaded question which may be easier answered if you have a particular style or "look" your after.
I have T.I.S. (Twenty Inches Strong) 6 lug, 20's on my '67 that were bought for a Tundra(?), they may not make a wheel that fits your style or the "theme" of your truck. I would go buy one of those Low Rider magazines (only because they have a ton of wheels in different styles) to help determine what your after. I hope this helped a little....... ![]()
R.I.P. Scott Kalitta
Here are some better photos of the wheels on my truck, as promised.....
I think this is the best "wheel" photo, ![]() ![]()
Nothing to see here.....
![]() Join Date: Jun 2007
HoupPhotography
I do love your truck!!! How's the 15 x 8's coming?!
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 05-18-2008 at 05:12 PM. |
I Guess The Overall goal is More of a Hotrod Look,,Maybe 5 inches lower all the way around with a Slight Rake.On The rear I want The MAXIMUM Tire width possible.So I was wondering who all might Make some Rims for the Back about 12" Wide In either 18"Dia or 20"..I Thought This might Have Been done Before,But The 6 Lug Throws it off I am Sure. I am somewhat dedicated to The 6 Lug as I already have SSB 4 wheel disc Brake Kit for it. Another Thing I am unsure on is if to use a Spring and spindle type Lower Job Or an Air Bag set-up,I Have a 750 hp BBC Sans The N2O.A TurbO 400 With a gear Vendor OD,and Will drive it to The Track etc and when I Put a set of Slicks on it,Id Like it To Hook Up. The Big Picture would be a 10.50 truck with AC.It is a Long Bed in Case anyone wants to Chime in with Hi-Po Rearend Chassis suggestions.Thanks
#6 | |
#7 | |
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 05-22-2008 at 04:10 PM. |
Here are 17x8 and 17x10. 6 lug Coddington's Smootie ll's I don't think 12 wide would fit and still keep the tire inside the fender. Click on my build thread below if you want more photos.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
Thanks for the pics.And The info.
ultra makes the 296. ive got them on my 68 in a 20" there are a few pics in my build thread.
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
Thanks Ill check um out.
67-72 Addict!
centerlinewheels.com
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
