Does my truck have a computer?
1986 Silverado, 305, Quadrajet Carb, Auto, and Bone Stock. I've always thought that this truck had a computer but I am being told that it only has the ESC spark control and that it is not really "computer controled". Is this correct? thanks.
![]() 2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado |
Cruzzzn' Vet
Re: Does my truck have a computer?
I think the Computers were Calif only
You want it there when???
I have an 86 Silverado with a 400 sb and Q-jet in it and mine doesn't have a computer on it.I don't think they came with a computer till 87 but I could be wrong.
1986 Silverado Flatbed 400 SB with 350 turbo 1997 Ford Explorer with 302 mydrive to work ride 1978 Gmc Midas RV 21ft with 46,000 actual miles 2003 Chevy Avalanche 5.3 327 and Tweety Bird Yellow Big Sandy Survivor 09 Trucks in the Blue Grass Survivor 09 TNCTC Streetcruzin |
BAD BOW-Silverado XST
Check behind the glove box. If you see a box bolted to the underside of the dash you have an ECS "computer". Another sign is a vacuum switch on the passenger side near the A/C box.
Yes, I do have the ESC computer and I understand that this device is to control the timing to prevent detonation. I think mine may not be working right and I've about decided to go ahead and disable it. I just wasn't sure if there was a brain in the truck like the newer models that controls everything else.
Arrived on a Pale Horse
Why not just swap it out? I'm sure the local bone yard has 20 or 30 available. Heck, I've got 2 laying around from trucks I've stripped.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
![]() Join Date: Oct 2006
You can also look on top of the carb. If it has a 'BLUE' solenoid on top and the distributor has a 4 prong plug instead of a VAC ADVANCE, then yes, your truck has a computer.
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT Last edited by manimal; 05-18-2008 at 03:13 PM. |
No, mine has the tan one and the dizzy has the vac advance.
I have one laying around too. ZZ4 does not have an ECS distributor.
Instructions to disable the ECS. http://www.73-87.com/7387garage/drivetrain/escrepl.htm |
Right on the line, baby!
Seems like a good time to cite Swervin's ESC to non-ESC dizzy swap.
on 73-87.com They're notorious for wigging out, that's why everyone's got so many hanging around.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
