Old 05-20-2008, 06:20 AM   #1
rick0312
rick0312's Avatar
bell housing?
I recently purchased a 3 speed tranny with a 4 5/8" bearing support. My old bell housing has a larger hole...about 5 1/8". Bolt holes line up fine, but bearing support hole is too large for new tranny. I think I need a new bell housing? If so, any insight on where i can purchase a 4 5/8" bell housing that will accomadate a 11" clutch, or could I still use the old bell housing?
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 05-20-2008, 07:14 AM   #2
rick0312
rick0312's Avatar
Re: bell housing?
can i use my original bellhousing even though there is some space between bearing suuport and bellhousing?
Old 05-20-2008, 05:12 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: bell housing?
_
I think you could if you are not going to be racing it or beating it too bad. I think I would try and find a machinist to make me a press fit adapter ring to go into the bell housing.
LockDoc
Leon
Old 05-20-2008, 06:56 PM   #4
prg machine
prg machine's Avatar
Re: bell housing?
It would be cheaper just to find the right bell housing........don't......I repeat don't run with that oversize bore..............your front bearing in the trans will be destroyed in short order and then you will wish you found the right bell. They should be easy to find.
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 05-20-2008, 08:04 PM   #5
69rut
Re: bell housing?
Have you tried to swap the bearing supports?
trailers are for boats
69rut is offline   Reply With Quote
Old 05-20-2008, 08:25 PM   #6
Green Machine
Green Machine's Avatar
Re: bell housing?
Assuming you want to keep the cast bellhousing for the side mounts, I think 1967 and earller had the smaller hole. You can purchase (i think) an adaptor ring or have one made, do not run with out the correct setup here, the tranny bolts will not center the tranny good enough to the clutch and will cause problems.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 05-20-2008, 11:18 PM   #7
prg machine
Re: bell housing?
there are plenty of the pre 67 bell housings with the side mounts. Just find one and it should cost less than even talking to a machine shop.I have picked em up for as little as 10 bucks in wrecking yards. Unless you have some personal attatchment to that particular bell housing give up and get the right one.
383 .040 over
Old 05-20-2008, 11:21 PM   #8
prg machine
Re: bell housing?
I must be missing something here...................but isn't that first picture the correct bellhousing? Why not use it?
383 .040 over
Old 05-20-2008, 11:15 PM   #9
prg machine
Re: bell housing?
The bearing supports correspond to the transmission input bearing that they belong on. Don't swap this out or youi open a whole nuther can a worms. Don't fool around here just get the right bell
383 .040 over
Old 05-21-2008, 01:29 AM   #10
Wrenchbender Ret
Re: bell housing?
The 435 4 speed came out in 68 & used the larger hole. An older bell housing or a 3 speed will fit providing it,s for the large flywheel.
Wrenchbender Ret is offline   Reply With Quote
Old 05-21-2008, 04:19 AM   #11
rick0312
rick0312's Avatar
Re: bell housing?
I have two trannys and one bell. the rebuilt tranny has the smaller support bearing. the older tranny fits perfect, but needs a rebuild. was hoping to reuse my old bell, but it looks like I will be seraching for the small bore size.
Old 05-22-2008, 04:59 AM   #12
rick0312
rick0312's Avatar
Re: bell housing?
So if I am understanding corectly I need a pre- 67 bell housing, with the side mounts. I am using an 11" clutch, so will any pre 67 bell that cam off of a sbc V8 be ok for the clutch size i am using?
Old 05-22-2008, 05:38 AM   #13
Green Machine
Re: bell housing?
I think the break is 67-68, so look for a 67 or older, all the 6 banger housing I have seen are the same as small block too.
Old 05-22-2008, 07:31 AM   #14
rick0312
rick0312's Avatar
Re: bell housing?
thanks!
