05-20-2008, 11:13 PM | #1 |
BBC LWP, brackets, pulleys, towers, SBC headers, Griffin rad, more
I figured I should put this stuff up here before I test the waters of evilBay. The larger stuff im going to post on Las Vegas CL as well. All items shipped from 89129.
Brand new 8851 Edelbrock Victor series aluminum long water pump. Installed only to be removed and swapped out for a short unit. $175 shipped Internal resivoir working PS pump and LWP repop brackets. Didnt squeel or leak when I pulled it. Brackets have never been installed. $65 shipped Long water pump pulley and crank pulley. I rattle canned them with a few coats of duplicolor and a coat or 2 of clear. 3 groove crank, 2 groove water pump. $40 shipped. Long water pump passenger side alternator bracket. $ 15 shipped Delco Alternator. Unsure of output. Worked when I pulled it. Free+shipping if anyone needs it. 73-87 SBC frame towers, drilled for installation in a 67-71 with a BBC. 2 clamshells with grade 8 bolts. $40 shipped. MSD 90* angle boots. New in box. 8 of them, included is a few plug contacts. $20 shipped Stock BBC LWP. worked well when pulled, no leaks. $20 shipped. SBC Hooker Comp headers. Passenger side number 8 tube modified by a muffler shop to clear the control arm. $120 shipped 2 Aluminized DEI wire sheaths. $5 shipped Griffin Aluminum 2 core race radiator. Brand new, never used. 30 5/8" x 19 x 3 overall. Slightly narrower than the stock 4 core. Stock brackets could be recolated and used. $175 shipped
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e Last edited by chevy72blu; 05-21-2008 at 12:25 AM. |
05-21-2008, 09:03 PM | #2 |
Re: BBC LWP, brackets, pulleys, towers, SBC headers, Griffin rad, more
ttt
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
05-22-2008, 02:11 AM | #3 |
about to go on ebay as well
05-28-2008, 09:56 PM | #4 |
PS pump and brackets, alternator, and the stock LWP are still availible (both free + shipping). I have 2 DEI aluminized plug sheaths that you can have if you need em as well.
05-28-2008, 10:36 PM | #5 |
BlahBlahBlah
Can you hold the engine mounts until I get an answer on whether these are the ones I need for sure? It will only be a couple of hours until I know...Hmm or maybe they are gone already?
Thanks, Mark Last edited by CG; 05-28-2008 at 10:37 PM. |
