Old 11-06-2002, 08:00 PM   #1
72hugger
lessons learned
I recently completed a conversion of my original 6 cyclinder 3 speed manual truck to a v8-350 automatic. I thought I would share some of my lessons. My truck had been coverted to a 305 v8 before I bought it. The engine was in the 6 cyclinder position.
1st lesson, you must get a different radiator or add a transmission cooler to add the automatic.
2nd lesson, you must get an automatic crossmember from a donor truck.
3rd lesson, not all tilt van columns that look like they will work will. The one I bought was too short. Make sure to check before you buy. I eventually bought an automatic column from the same donor truck that provided the crossmember.
4th lesson, the automatic linkage is almost impossible to find in a junk yard. The linkage is available from mothertruckers, but they were out when I need it. I used a universal linkage unit from krug komponets. I purchased it complete from Dixie Truck works in Mt. Pleasant, NC. It is a nice stainless steel unit. It is very clean and needed just a little modification to work for me.
5th lesson, the 350th transmission fit without modification of the drive shaft, if the engine is in the 6 cyclinder position. I chose this option.
6th lesson, if you remove the pedal bar for the clutch, you would never know without checking that the truck was converted.
7thlesson, using the 350 engine in the 6 cyclinder position, I chose to use the long water pump set up used on 73 and later trucks. This allowed me to add power steering. I used the gear box from a 79. It was a straight bolt up affair. It works great. It also puts the fan in the right place with in the shroud. I also needed a different alternator bracket. The problem with this set up is with the hoses. It took some time to find hoses that would work. I used a universal on the bottom, and a hose from a 305 on the top.
Finally, It was well worth the effort. I am much happier with the 350 over the 305, and I really like the automatic.
I hope this information is helpful to others.
72hugger
72hugger is offline   Reply With Quote
Old 11-06-2002, 08:10 PM   #2
crazy longhorn
Fabricate till you "puke"
On the bottom hose, you can run a mid 70s , if you change the neck in the radiator. i pulled the curved neck, & had the smaller dia mid 70s neck expanded at an ex shop(on the rad end), then soldered it back in.
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-06-2002, 09:03 PM   #3
Southpa
Southpa's Avatar
Regarding your mention of van tilt columns being too short. The one I pulled (from a mid-70's GMC Rally-Six) didn't have a steering arm. The rag joint was hooked almost directly up to the steering box. I used the steering arm from my old stock column and actually had to shorten it about 4".
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 11-06-2002, 09:09 PM   #4
72hugger
Yeah,
That was exactly it. It hooked directly to the steering box. I got frustrated and no one I knew thought that it would work. I wondered if it could be modified somehow.
Also thanks on the earlier post about the hoses.
72hugger
Old 11-06-2002, 09:25 PM   #5
Southpa
Southpa's Avatar
They all work, you just need that extra piece from your old column. Heres a great site on how to:
http://www.net1.net/~sas/TruckPictur...tallation.html
Original 350/TH350
Old 11-07-2002, 01:00 AM   #6
Slammed67
Progress = 0%
Slammed67's Avatar
For future reference.......
The shift linkage off a '73 - '?? can be adapted to a '67-'72 truck. All you have to do is bolt the pivot barcket to the frame. My engine isn't in a stock location, so I made up my own shift rod (the one that goes from the coloumn to the trans). Pretty easy to do, and is cheaper and more simple than the stock linkage. Somebody else on the board gave me that info.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
